Oil Analysis on Pennzoil Ultra
Old 07-20-2010, 10:31 PM
  #31
SM_Shadowman
SM_Shadowman's Avatar
Well I don't necessarily think they're recommending Mobil 1 for everyone. Like they said, and we have seen here, there have been mixed results with that one, but improvement as of late.
The way I'm reading that, it's just that he's been using it previously and has apparently been getting better UOAs with it than with the Ultra so they're recommending he go back to Mobil1.
Old 07-21-2010, 09:31 AM
  #32
KLB
KLB's Avatar
Got my results back. Mine looked good. I also posted it in the main UOA thread.
Old 09-24-2010, 06:22 PM
  #33
l2awin
l2awin's Avatar
Oil analysis #2
Oil.jpg?t=1285366884
Old 09-25-2010, 12:21 AM
  #34
TheLocNar
TheLocNar's Avatar
What filter were you using?
Those are pretty good results!
Old 09-25-2010, 01:25 PM
  #35
l2awin
l2awin's Avatar
Regular OEM filter. Does it matter that this is more high way miles? I'm thinking thats why the results are better this time.
Old 09-27-2010, 05:17 PM
  #36
philter25
philter25's Avatar
It could be, or some engines are still at the very cusp of break in at 20k.
The 1st oil sample was from the car at 15k to 20k, and the 2nd sample was from 20k to 25.5k. At 15-20k, you are still at the end of break in so you would still potentially expect a slight decrease in wear metals.
Id have a smile on my face, nice UOA.
Old 12-06-2010, 07:28 PM
  #37
wakeboardr116
wakeboardr116's Avatar
Here's mine for 30K. Things look pretty good to be despite the extra abuse from the track.
Old 12-07-2010, 12:21 AM
  #38
xyz
xyz's Avatar
4.2k . . . is pennzoil ultra safe for 5k interval for normal daily use?
Old 12-07-2010, 08:04 AM
  #39
wakeboardr116
I'm sure it is. I do some tracking and stuff so I just like to be safe and change it early. I'm slowly increasing the change interval each time on the ultra. I started at 3500, then just over 4000. I'll probably go 5000 on this change.
Old 12-07-2010, 09:55 AM
  #40
KLB
KLB's Avatar
I've been running Ultra 6-7.5K. I have a couple of UOAs on here. The results were good.
Old 12-27-2010, 08:34 PM
  #41
l2awin
l2awin's Avatar
6.5K interval
Old 12-28-2010, 09:33 AM
  #42
philter25
philter25's Avatar
^Flashpoint is low..... probably a mistake. Looks great though.
I think once my engine is broken in Im going to use Ultra. Whats your driving style? You seem to put much more miles on your car than I do, are you getting stuck in stop and go traffic around DC or is it smooth sailing highway? Aggressive driver?
Old 12-28-2010, 04:27 PM
  #43
l2awin
l2awin's Avatar
My current commute is from North Bethesda to BWI area. It's pretty smooth aside from the occasional traffic on 495. Semi-aggressive driving, enough to keep the engine happy.
Old 12-29-2010, 01:24 AM
  #44
CougarRed
CougarRed's Avatar
Maybe not. Flashpoint is negatively impacted by fuel dilution. Blackstone Lab normally does a comparatively poor job of measuring/reporting fuel dilution. Here, they report 1.3% vs. < 0.5% the last 2 UOAs.
If fuel dilution was indeed high, the low wear metal count is all the more impressive. Most any oil will do a decent job in the absence of significant fuel dilution. One of the tricks of finding a good oil is one that will protect in the face of high fuel dilution.
Old 12-29-2010, 10:52 AM
  #45
l2awin
l2awin's Avatar
Talked to LabStone and did some googling on the fuel dilution. A possible explanation may be due to excessive idling to warm up my car in the winter. I will try to idle for 1 min or less and see if it will go down in the next test.
Quick Reply: Oil Analysis on Pennzoil Ultra
