FI Preparation...
Old 05-22-2010, 10:11 PM
VossenG37S
VossenG37S's Avatar
Very cool man
Old 05-22-2010, 10:31 PM
DmfG37sTT
DmfG37sTT's Avatar
Nice job, Im looking for a set of gauges myself for my G
Weiboy718
Weiboy718's Avatar
Originally Posted by BlkHR37S
Very cool man
thanks! that's only half done. still need sensors and AF meter.
Old 05-23-2010, 07:20 AM
Q8y_drifter
Q8y_drifter's Avatar
I just found out that the Greddy does not support ECU A/F readings
So lets see...
HKS Camp 2 - No AFR except with F-Con
Greddy Infotouch - No AFR for V36
Magden - Discontinued
Blitz R-Vit I-Color - May or may not view AFR.
what other choices do we have for monitoring systems?
Old 05-23-2010, 09:50 AM
Weiboy718
Weiboy718's Avatar
So lets see...
what other choose do we have for monitoring systems?
not much options to choose except to go all analog with a custom pillar pod. i really like the CAMP 2 though. you can set warnings for everything. a red light blinks if you go over a certain rpm, boost, temp, voltage, egt, speed. everything you have in there you can set a warning point. so far i'm very happy with it and best of all is i'm not using my AUX to view it so that means i can still play my music while it's on CAMP 2. just a flip of the switch the screen will go back to normal.
Old 05-23-2010, 11:49 AM
terrycs
terrycs's Avatar
... i'm not using my AUX to view it so that means i can still play my music while it's on CAMP 2.
The CAMP2 doesn't have RGB outputs so you have to go through the AUX inputs. If you can hear audio while the CAMP2 is up, you'd first have to convert the signal to RGB. Only then you can go direct to your LCD.
Old 05-23-2010, 12:00 PM
Weiboy718
Weiboy718's Avatar
i bought a module that bypassed the nav screen. what it is, is this module comes with a video input and a RGB output to my nav screen. a piggy back. i am not interfering with my car's audio system. i'm only borrowing my nav screen.
Old 05-23-2010, 12:04 PM
Wei, will you PM me exactly what all you purchased along wit the CAMP 2? I'm thinking off going the exact some route myself. Any info about your install would be great too.
Old 05-23-2010, 01:38 PM
whiddles
whiddles's Avatar
me too.
Old 05-23-2010, 02:44 PM
Q8y_drifter
me 3!! I guess I'll just settle with the CAMP 2 and get me an AFR gauge.
Problem is I don't have the AUX, just the A/V inputs. Man i want the USB option from the 2010 models!
Old 05-23-2010, 02:56 PM
Weiboy718
Weiboy718's Avatar
you do have the aux mode. you can connect your a/v from you camp 2 and run it inside your center console to the a/v inputs. but you have to do something else to make it work properly. very easy diy! pm me if you want more info about that.
Old 05-23-2010, 03:06 PM
Q8y_drifter
well yeah i do but not the AUX connection that is on the Navi equipped cars.
Old 05-23-2010, 03:43 PM
Weiboy718
Weiboy718's Avatar
huh? we have the same thing. A/V inputs inside of the center console. is there something i don't know about???
Old 05-23-2010, 04:53 PM
  #29
Q8y_drifter
sorry i meant the audio jack next to the A/V inputs. we call it Auxiliary Jack or just AUX input here.
Old 05-23-2010, 04:57 PM
  #30
Weiboy718
Weiboy718's Avatar
we have the same thing. nothing different other than a ipod input.
