Help cobb or UPrev
Old 04-18-2010, 02:37 PM
Bahrain5666
Bahrain5666's Avatar
cobb or UPrev
simple and easy question
i wanna tune my car!!!
should i go with cobb or uprev???????????
suggestions please
Old 04-18-2010, 02:45 PM
whiddles
whiddles's Avatar
a lot will say uprev but cobb is easier to use. i say cobb
Old 04-18-2010, 02:48 PM
Bahrain5666
thanx bro..
easy or hard is not an issue,,
performance is what im looking for...
my mods are : stillen gen 3, FI test pipes, and invidia gemini exhaust
Old 04-18-2010, 02:51 PM
hispeed-lowdrag
hispeed-lowdrag's Avatar
I'm not sure if you are talking about the Cobb accesport, but if so you aren't supposed to use Cobb with ANY aftermarket intake. I would have bought Cobb a long time ago if it was ok to use with the Gen3
Old 04-18-2010, 02:52 PM
Bahrain5666
mmmmmmmmmmm i read that before but i wasn't sure about it!
now u proved it to me!
Old 04-18-2010, 02:58 PM
whiddles
whiddles's Avatar
Uprev and cobb are the same for tuning. the cobb comes with reloaded maps which are not for intakes. This is why you need the custom tune,
when you by up rev you buy their maps and a custom tune as well. To uninstall uprev you have to go back to uprev.
install and uninstall with cobb is plug and play. Cobb also shows live data. Uprev does not. Unless you use a laptop with the set up
Old 04-18-2010, 03:00 PM
Bahrain5666
but which will give me more gains?
hispeed-lowdrag
yeah I am thinking about getting the Hypertech Max Energy Sport, everyone that has used it had nothing but good things to say about it and it doesn't have the restrictions of the Cobb
Old 04-18-2010, 03:03 PM
whiddles
whiddles's Avatar
what restrictions does cobb have. it tunes everything the others do and its yours. handheld
whiddles
whiddles's Avatar
all have the same gains. really depends on a tuner
Old 04-18-2010, 03:05 PM
Bahrain5666
hmmmmmm interesting..
Old 04-18-2010, 03:07 PM
hispeed-lowdrag
cobb is restrictive on what setups you have...I guess you could use it with anything but they say dont use it with aftermarket intakes/etc
Old 04-18-2010, 03:13 PM
Bahrain5666
is it true that cobb wont work on gulf specs cars?????
Old 04-18-2010, 03:40 PM
whiddles
whiddles's Avatar
not sure of golf specs but the cobb has standard maps which are the ones you can not use with intakes. i run stage 2 map right now cause i do not have a custom tune
Old 04-18-2010, 03:42 PM
Bahrain5666
so i guess ill go for the UPREV ...
Quick Reply: Help cobb or UPrev
