not sure of golf specs but the cobb has standard maps which are the ones you can not use with intakes. i run stage 2 map right now cause i do not have a custom tune
what I'm confused about is that the notes for stage 2 says "Stage2 91 v103 - Intended for 2003-2009 Infiniti GSeries otherwise stock vehicle with a stock or cat-back exhaust, high flow catalytic converters, and STOCK INTAKE SYSTEM ONLY"
but then you have the Gen3 intake...have you had any problems with it?
nope run a little rich but i plan on getting it tuned. the cobb can tune the car with all mods except twin turbo. cobb will be tuning my SC kit when they come in. i feel no need to keep uprev.
ok, so the cobb accessport is ok to run with ANY mods except TT? Like I'll be running the Gen3, ARK exhaust, and possibly HFC's
