2010 AT fluid? Matic K?
The user manual says it uses Matic S but there's no filling tube on the transmission. It's supposed to be dealer serviced only.
Yes you are correct the only way to fill the transmission is with a special tool only the dealer has. Its also a lenghthy process of heating up and cooling down the fluid to get the correct level.
There is no recommended interval in the manual - it's a sealed unit so only the dealer can determine if any service is required.
butwhatuptho
10-04-2015 07:51 PM
