FI Decision Thread
Old 03-25-2010, 08:07 AM
  #121
G37Sam
G37Sam's Avatar
Originally Posted by philter25
People should read maximum boost by corky bell.
I second that
Old 03-25-2010, 08:21 AM
  #122
WhosUrBuddiee
WhosUrBuddiee's Avatar
^^True, you can install a pressure gauge anywhere you want. The most common is on the manifold, but really no set standard.
Old 03-25-2010, 08:22 AM
  #123
WhosUrBuddiee
BTW
I am ordering this catch can !!!
Old 03-25-2010, 10:19 AM
  #124
superchargedg
superchargedg's Avatar
James get the GTM kit....enough said.I didnt know you had an old stillen blower on your G.
Old 03-25-2010, 10:48 AM
  #125
WhosUrBuddiee
My first G35 had a stillen blower.
My second one I did the Venom nitous set up.
Old 03-25-2010, 12:39 PM
  #126
Mike
Mike's Avatar
And to add to the where to measure PSI debate above...... depending on where psi is measured, it might not be accurate to compare two systems. 7 psi in one system and 7 psi in another system might not have the same psi charge entering the engine. There can be some losses going through intercoolers.
Im curious to know more about Stillen's air to water intercooler built into the manifold. My first original thought was there doesnt seem to be that much area inside the manifold, so to get sufficient cooling this system might be more of a restriction than the front mounted intercooler in the GTM system...... although water to air has about 4 times the cooling capacity of air to air.
I havent seen a flowchart or diagrams or any good descriptions or pictures of the inside of Stillen's air to water intercooler. Does anyone have them or is this a proprietary design by Stillen and are they keeping them under wraps?
Air-to-water IC (usually incorrectly referred to as a Aftercooler) are more efficient at pulling out heat, but are more prone to heat soak, since most kits are not designed for long pulls and/or long sessions of WOT. A heat exchanger has to be used to keep the water temp down. For short sprints, this is awesome, as you can ice down the AC to cool your charge temperature even more.
Vortech kits often use a air-to-water IC on other cars... but most people running much more than the kit's stock power usually swap out to a air-to-air IC. See their Mustang or S2000 kits for example.
The design remains yet to be proven... only time will tell.
Old 03-25-2010, 12:52 PM
  #127
whiddles
whiddles's Avatar
So are you saying for a daily driver air to water is no good?
Originally Posted by WhosUrBuddiee
BTW
why you need this?
Old 03-25-2010, 12:59 PM
  #128
Mike
Mike's Avatar
It's perfect for most daily drivers, unless you're doing extended WOT pulls to very illegal speeds. Air-to-water is more compact and more efficient, but there is a limit to the speed at which it can pull heat out of the charge before it gets overwhelmed (just how a air-to-air IC that is too small will get overwhelmed).
Old 03-25-2010, 01:09 PM
  #129
whiddles
whiddles's Avatar
roger that
Old 03-25-2010, 01:36 PM
  #130
WhosUrBuddiee
I actually want to talk to Stillen about using ethylene glycol/water solution instead. Very high effiency and less chance of being overwhelmed.
(Posted wrong solution before)
Old 03-25-2010, 01:38 PM
  #131
whiddles
whiddles's Avatar
Yeah i just want to have the extra push on highway when a mustang or z06 pull up
Old 03-25-2010, 01:41 PM
  #132
Mike
Mike's Avatar
I'm not that familiar with ethylene glycol, but isn't that antifreeze? It has a higher boiling point than water, but I believe the thermal capacity is lower than water...
I used just distilled water when I had my vortech on the s2k, but if there's a way to improve the system, I'm all for it.
Old 03-25-2010, 01:49 PM
  #133
WhosUrBuddiee
It is basically antifreeze. You can use it in tandem with a glycol cooler. All you really need is a small pump, cooler, and small heat exchanger. The reason the glycol is used is because the temp can drop down to 32 degrees.
I dont know if it is feasible or cost effective at this point. In the beginning, I just plan on using the stock Stillen setup and going from there.
Old 03-25-2010, 02:02 PM
  #134
WhosUrBuddiee
Here is a small one.
Cools it down to -10 degrees celicus.
1360 BTU/hr steady state.
Yes it is not nearly powerful enough to keep it chilled at that temp, but it could help keep the temp down.
Old 03-25-2010, 02:07 PM
  #135
WhosUrBuddiee
I really havent looked much into it. I will install the Stillen setup as is and go from there.
Quick Reply: FI Decision Thread
