Review Got my car logged via UpRev Cipher
![](/images/staff.gif)
Yeah the guy with the cipher told me two 2nd gear runs were more than enough.. so I took both data logs and averaged them out as the numbers were too close anyways. I also averaged the readings from both left and right headers.
I'm also using an equivalent of 91 octane fuel, wonder how the ignition timing chart would change if I upgrade to 93.. I can see where the "93 octane yields more power" argument comes from now
Whoever told you that sure had something illegal in his blood ![Smilie](https://www.myg37.com/forums/images/smilies/smile.gif)
It does not "ignite" better, it's just more resistant to knock. Our engines are smart enough to detect knock, something very probable with an 11.0:1 compression ratio (Most ferrari's use 11.2:1 btw!!), and compensate for that by retarding ignition timing, to a point where you have no more knock. Higher octane will allow the engine to advance timing a little which is where you'll see your gains from.
Just thought I'd clear that out as it's a very common mis-conception
350zrunnin12s
08-09-2015 09:55 PM
