Gas Grades
Old 01-08-2010, 11:43 PM
G Nack 37s
G Nack 37s's Avatar
93 always
Old 01-08-2010, 11:46 PM
MechE
MechE's Avatar
Originally Posted by JohnEnglish
I run what the manual says which is premium.
There are a lot of factors that influence octane rating, cam profiles, combustion chamber design, timing, etc. All these thing influence the actual combustion of the air/fuel mixture and how the pressure of ignition is handled.
Thank you John.
Old 01-09-2010, 03:43 AM
chasemyaccord
chasemyaccord's Avatar
91 since I can't go any higher...unless I get 100 at a place near my work, but why in the hell would I do that hahaha.
Old 01-09-2010, 04:06 PM
911turbo
911turbo's Avatar
premium shell only, unless i'm out in the boonies lol
Old 01-09-2010, 04:31 PM
BOXER83
BOXER83's Avatar
It's tell's you in the manual premium gas only
Old 01-09-2010, 04:35 PM
BOXER83
BOXER83's Avatar
The RPM rev too high not to use 93+
Old 01-09-2010, 05:22 PM
juicybusa
juicybusa's Avatar
In general just the opposite is true- the higher the rpm the less octane required.
Old 01-09-2010, 05:45 PM
ShyTown91
ShyTown91's Avatar
why not get 93 instead of 91? usually its only .05 more expensive thats 1 dollar for every 20 gallons
Old 01-09-2010, 06:04 PM
Chekov
Senior Citizen
Chekov's Avatar
(Sigh) Some posts here are as misguided as past threads on this often-repeated subject. Higher octane beyond what is required to prevent detonation is a complete waste of money, for higher octane in this range does not give you any more power or performance.
For those so inclined, you might as well open your window as you drive, throw out a dollar bill every few miles, and shout, “Veroom, veroom.”
Old 01-09-2010, 07:14 PM
DashKid
DashKid's Avatar
i follow the manual it says 91 or better but in TX they only have 93,89,87
Old 01-09-2010, 07:21 PM
Chekov
Senior Citizen
Chekov's Avatar
In your case using 93 is preferred over the 89, because some performance may be lost as the ECU retards the timing to prevent knocking. However, if you want to take the trouble, you could combine both 93 and 89 when filling up to get close to 91, which is all you need.
joey_v
joey_v's Avatar
I'm kind of stuck because my choices in Chicago are 93 and 89.... maybe I should do half and half to hit 91 and save?
Old 01-09-2010, 07:22 PM
BOXER83
BOXER83's Avatar
Then why do they run a higher octane for crotch rockets, ferrari, lambo, and all the supercars????
I run 93 in my bike andis maditory
Old 01-09-2010, 07:28 PM
  #29
Chekov
Senior Citizen
Chekov's Avatar
Because those engines have much higher compression ratios than ours and need higher octane to prevent detonation. Where the G37 is around 10:1 a typical Ferrari is 12.5:1 or more.
Old 01-09-2010, 08:27 PM
  #30
Mike
Mike's Avatar
compression is only one part of the equation.
You could make just as much power on lower octane reliably, if you were willing to spend the money on a Motec.
If you can't pay, don't play. Put in 91. Premium car, premium maintenance, premium fuel, and of course, premium price.
Quick Reply: Gas Grades
