Running too lean
Old 12-03-2009, 04:20 PM
SilverBullet
SilverBullet's Avatar
Sam, get a Cobb AP and street tune it.
Old 12-03-2009, 04:31 PM
G37Sam
G37Sam's Avatar
Man I said it like a million times on this forum lol, Cobb AP don't work on Gulf Spec cars..
Will mostly get her chipped and call it a day
Old 12-03-2009, 04:32 PM
SilverBullet
That true. I remember you saying that. I would do the chip, cause you will get benefits.
Old 12-03-2009, 04:59 PM
ucla bruin
ucla bruin's Avatar
Originally Posted by cvt
I've already been to Technosquare. My Z was flashed after I got headers...are you confused?
Sorry that was directed at Sam. Will edit original post.
__________________
Old 12-03-2009, 05:07 PM
G37Sam
G37Sam's Avatar
Even if I send it to them, how are they going to tune it exactly for my car? Data-logging? Naah that's weaksauce.
Tadashi should come down to Dubai!!
Old 12-03-2009, 05:08 PM
Age
Age's Avatar
So if your running too lean and you guys say your heading towards detonation what exactly do you mean?
Old 12-03-2009, 05:15 PM
G37Sam
G37Sam's Avatar
Well not that bad, but could lead there in extreme cases.. too much unburnt air might recombust in your combustion chamber after the initial ignition basically
Old 12-03-2009, 10:01 PM
cvt
cvt's Avatar
how did that rod bend like that?? LOL was it an untuned FI car running high boost?
Old 12-04-2009, 02:16 AM
G37Sam
G37Sam's Avatar
I have no idea to be honest lol I got it off an interesting article on engine detonation I found while looking around
A lean fuel mixture, more air than fuel in the combustion charge, is another known detonation culprit. The lean mixture burns hotter and absorbs less heat in the process, hence EGTs rise when the mix goes lean and adding fuel drops temps. This heat can rise to where the mixture starts burning out of sequence with timing events and bam you have detonation.
Old 12-09-2009, 03:41 PM
G37Sam
G37Sam's Avatar
I'm curious to know, why do breathing mods alter AF numbers in the first place.. aren't AF numbers stored in some sort of tables in the ECU.. how does adding an intake alter that?
Old 12-11-2009, 03:12 PM
Q8y_drifter
Q8y_drifter's Avatar
I'm just as curious. The car "should" be able to adjust to air/fuel changes, especially when you consider that there is more oxygen in the air in winter than summer, and more at sea level than higher above. How can the ECU adapt to such changes and not adapt to intakes?
Old 12-11-2009, 03:37 PM
cvt
cvt's Avatar
simple answer would be that the intakes and exhaust provide too much air flow for the ECU to handle. remember that the ECU, while it does 'adapt', it only apadts to the RANGE it was programmed with...it only 'adapts' to the a/f on a stock air box and exhaust system. so the readings on a cold / hot day with a stock air box will be over and beyond the 'safe range' of an intake designed to manipulate the a/f for more power in the same conditions when combined with more breather mods.
if the ecu had such a broad adaptibility range...then everyone would just slap a turbo and call it a day without ever worrying about Sam's pic....LOL, i still find that funny.
Old 12-11-2009, 04:22 PM
Q8y_drifter
I see. so can dyno tuning adjust the A/F range without using a specific tuner tool such as those from Cobb or Uprev? i mean is there a universal tuning tool to do that? especially since both Cobb and Uprev don't work on GCC cars
Old 12-11-2009, 05:53 PM
  #29
G37Sam
G37Sam's Avatar
Thanks for the clarification, there still are some vague areas in my head though, from what I know, the MAF sensor reads the mass of air entering, it then divides that by the A/F ratio obtained from the tables in the ECU (based on RPM, TPS, etc..) and injects the required fuel.
So you replace your stock intakes with ones that improve the flow and cause more air mass to flow in, why is it we have a problem? Is the MAF sensor having troubles reading the new added air? Or is the ECU having troubles obtaining that signal input from the MAF sensor?
Old 12-11-2009, 06:40 PM
  #30
juicybusa
juicybusa's Avatar
Because the design range of effective compensatory adjustment is based on stock intake and exhaust- it can adjust but only to a limited degree
Quick Reply: Running too lean
