Ignition Question
Old 10-22-2009 | 12:44 PM
2008G-Man's Avatar
2008G-Man
Ignition Question
I think I know the answer already but just in case I missed something. Seems foolish to me that if you need to turn the ACC on without starting the car, you need to cycle past ON to get to OFF. Is there a shortcut to go from ACC to OFF, bypassing ON (sounds like a board game)?
Old 10-22-2009 | 01:25 PM
PeterUbers's Avatar
PeterUbers
A double click will get you from ACC to OFF.
A double click while the engine is running and in park/neutral will get you to ACC with the engine off.
Old 10-22-2009 | 01:46 PM
2008G-Man's Avatar
2008G-Man
cool ...... is that a true bypass or just a quick cycle past ON? Sorry, not near the car for a few days to test myself.
Old 10-22-2009 | 02:35 PM
vukhey's Avatar
vukhey
I just checked it, you actually cant go from ACC of OFF w/o passing ON, you can however go from engine in idle to ACC with a double click, but to turn off from there, you would have to cycle through.
Old 10-23-2009 | 08:02 PM
kevmi2ca's Avatar
kevmi2ca
If I leave the clutch out and press the ignition button I get ACC.
gdaelemans
09-15-2015 01:20 PM
Detailed Image
Lighting/Cleaning Products
09-14-2015 08:24 AM
gdaelemans
09-13-2015 10:36 PM
