Help! HFC CEL
Help! HFC CEL
PLEASE HELP!! I have Berk HFC, FI exhaust and Stillen Gen 3 intakes. I have a P2A00, bank one sensor one code coming up. I have replaced the O2 sensor in the header due to the dealer ship saying that the sensor was not reading right. A few days later the light comes back on and the dealership resets the A/F learning ratio and a day later the light is back on. The dealership says that the sensor is fine and due to the mods the car is running lean at idle and the senor is not fixing itself fast enough and trips the code. The said the A/F is fine once you start to give it gas and is only lean at idle. I was wondering if anyone else has had this same problem with their setup. Also will a Cobb AP and a custom tune take care of the problem since the sensor in checking OK?
I threw a code in bank 2 recently, was no big deal. With ur intakes and HFC's, you're passing too much air and it trips the code. Not a big deal but annoying. And yeah, a Cobb can be programmed to ignore selected codes if you chose (i've been told).
SON415
09-28-2015 05:49 AM
