Paddle shifters
http://g35driver.com/forums/v36-diy/...t-paddles.html
super easy to do (with the possible exception of that torx screw)
Hey all...I have a G37 base...Anyone know if this mod is possible? The steering column is manually adjustable, not electronic..Also is a willow interior, which I'm worried won't have the appropriate trim color available...
I just finished the paddle shifter install on my '09 G37X Sedan. It took 1 1/2 hours start to finish. I DID NOT remove the steering wheel, that was not necessary. I rotated the steering wheel to the left and then right, removed the two screws on the front that are hidden by the steering wheel and removed the bottom screw. To ease removal of the finishing piece, I had the wheel all the way up and out. I also removed the small finishing piece underneath the steering wheel and the two screws holding a metal cross brace. That made removing the stock piece fairly easy. From there, follow the DYI in the G35 forum and the rest is easy.
37
10-17-2020 11:12 AM
mikysee
09-28-2015 11:18 AM
