Time for an oil change?
When changing your oil, just curious to see what schedule most follow?
- Synthetic vs regular? and frequency?
- Which brand do you use, and does brand matter?
- Do you take it back to the dealership, your own mechanic, or are you a DIY'er?
Dude....you really should have searched:
https://www.myg37.com/forums/general...il-thread.html
That should answer your questions.
I'm sure this will generate a lot of interesting responses.
Yes and Yes. Frequency as per manual (3750 or 7500 miles) depending on driving conditions and preferences. Just check your oil level regularly.
Read the manual - 5W30 that meets specs. Nissan Ester Oil if you feel you want the recommended OEM fill and/or if you have the VVEL tapping issue.
Doesn't matter as long as it's documented. Personally I'm typically a DIY'er but with my new cars I tend to use the dealer and in this case purchased a maintenance plan.
