Does it smell bad when you ride the clutch??
Old 05-29-2009, 06:19 PM
boostard
boostard's Avatar
Engagement point of a clutch isn't necessarily indicative of its overall surface area. In fact there are other and much more pressing variables which can and will modify that issue.
Old 05-29-2009, 06:26 PM
Mike
Mike's Avatar
what the surface area of the clutch disk have to do with the friction zone of the clutch pedal? It has to do with the thrust exerted on the clutch/flywheel by the pressure plate. The clutch is either 1. not clamped to the flywheel, 2. clamped, but a low enough force that it is still slipping, or 3. clamped with sufficient force to have no slippage.
#2 has a rather large zone on the G37, similar to a lot of VWs.
The OP just needs to stop riding his clutch, or face a rather expensive clutch replacement bill
Victory
17
10-27-2022 03:45 PM
eljoker
Future Models
19
05-30-2022 11:48 AM
ZSpeedPerformance
Drivetrain
12
09-09-2016 11:20 AM
AMCDeac
General Tech Questions
09-19-2015 05:25 AM
claudiohv
09-17-2015 01:43 AM
Quick Reply: Does it smell bad when you ride the clutch??
