GT Motorsports: GTM Stage 2 TT G37 Coupe, GTM 3" Cat-Back, GTM Flash, 611RWHP/47
#317
That is the boost my boost controller making the noise , I have the warning beep on when hitting 10 PSI - subsequently I also have the "limit" safety feature on that applies negative % to boost when exceeded 10.1 PSI. I decided to enable this feature after reading the online manual, in order to prevent overboost and to maintain a more constant 10psi
basically you can set the boost to a number 0-100, the number is relative to power in a way but changes depending on weather factors. You have to play with it and figure out what number corresponds to your PSI goal for that setting. Once that is done you can program it not to go over that PSI number - if it does it will warn you and apply a negative amount (customizable) to the current setting to bring the boost back in line.
#318
Fancy! however that beeping noise would p!$$ me off. I took out the seatbelt sensor and door sensor cause I hate those beeping noise that bad! I guess you can call it a pet peave
#319
Slave cyl turned out to be factory slave cyl, with os gieken bearing. GTM is sending the bearing over to Hills Garage- thanks for all your help Sam.
