Help Switching back and forth from one type of oil to another?
Oil has been talked to death, but I couldn't find anything to help me with this particular question.
I've been taking my G37 to the dealer to get the oil changed regularly and I have no idea what they put in it. I know it is 5w30, but I don't know if it is synthetic or not. They once told me it was conventional Mobil, but I thought Mobil only made synthetic... so who knows. Then the whole Ester oil fiasco happened and they put Ester oil in once or twice (free of charge because it was related to the TSB).
Well now I want to start taking my own oil to the dealer to save money until I move somewhere where I can change it myself. Costco has Mobil 1 5w30 synthetic on sale right now so I'm thinking about having that put in... but my question is... does switching around from whatever the dealer used (possibly synthetic?) to Ester to synthetic again cause any problems?
Please don't turn this into a thread about which type of oil is better - I just want to know if switching to/from ester <-> synthetic <-> conventional and/or back will hurt anything.
But you SHOULD try to pick an oil and stick with it. I'm doing the same thing and bringing my own oil to the dealership at my next service and will probably do so from now on, unless I start doing the service myself.
Let the arguments begin
Your seasoned mechanics should stick to turning wrenches. Part of API oil specs since the beginning of time is that all oils have to be fully compatible. You are not going to have any reaction in your engine. You do realize that synthetic blend oil is just that - synthetic and conventional oil mixed together in the bottle on the shelf. How do you suppose such a product could be sold? Not only can you switch at each change, but you can GASP mix oil together. You could even mix 5 different quarts together at your next oil change with no ill effects.
There is just a bottomless pit of oil misinformation and OWT.
Lt8Che
91
04-08-2022 04:55 PM
