Companies Who Plan On Having A Supercharger For The G37
Old 03-02-2010, 08:43 AM
  #181
MMC Racing
MMC Racing's Avatar
Originally Posted by ozzypriest
How long will the stock engine internals be able to handle 8 psi boost? It's a high compression engine as it is...? And, and predictions for the transmission at 100+ ft/lbs of torque over stock?
What makes you think it won't last 200,000 miles? Boost level on its own is almost meaningless. We aren't talking 15psi here, we are talking 8.. As always with a new platform, only time will tell. My feeling is 10psi with a free flowing exhaust will be considered the safe pump gas upper limit of the stock block.
Old 03-02-2010, 09:46 AM
  #182
Q8y_drifter
Q8y_drifter's Avatar
Terry's GTM TT G sedan pushing over 450whp have been going for a couple years now. It his DD.
Old 03-02-2010, 02:54 PM
  #183
ozzypriest
ozzypriest's Avatar
I don't know - that's why I'm asking. It all sounds good to me.
Old 03-02-2010, 03:47 PM
  #184
G37Sam
G37Sam's Avatar
Depends on how you drive it too, if you're going to race it at every stop light etc, it might die quick. Boosting an N/A engine is always a gamble
Old 03-03-2010, 10:57 PM
  #185
Team STILLEN
Team STILLEN's Avatar
Wanted to give an update on the progress of the STILLEN supercharger, as well as a dyno sheet of the kit. As you are aware our initial installation has been our automatic G37 with large show wheels.
Over the last couple of weeks, the car has been up on the dyno, finalizing the tuning, and more recently, and importantly, tuning off the dyno (for drivability and loaded performance). We’ll have some pictures and videos of the driving tests put together soon. Below is a dyno sheet run of the CARB-planned kit on the automatic G37.
3rd Gear Run - G37 AT - 500+hp / 422whp - CARB-Planned Kit
Dyno testing and tuning is only a small portion of what goes into the engineering behind a STILLEN supercharger system. Tuning on a dyno versus under load on the road and track are two very different tasks. Also, dynos can’t really simulate race track experiences and how the car responds to heat, oil breakdown, increased operating temperatures and long duration load. Sure, it’s possible to come up with theories on the performance of vital components such as intercoolers and oil coolers but theory does not compare to experience and testing.
A dyno can’t tell you what the airflow looks like through your vital coolers when the car is on the track. Or how many laps you’ll be able to complete before your car goes into limp mode. It has always been a priority of STILLEN to offer a supercharger that can complete every minute on the track, not to mention survive on the street in hot conditions.
As we mentioned before, we have been undergoing extensive drivability testing, both around town, as well as being pushed to the limits and beat on in a test track environment:
  • Repeated high speed runs in excess of 140mph
  • Temperature monitoring (just a few of the many data points we collected during our testing)
  • IAT pre and post intercooler under hard driving conditions
  • Engine Oil under hard driving conditions
  • Intercooler coolant under hard driving conditions
  • Transmission performance under hard driving conditions
  • Effects of airflow to new coolers without impeding flow to radiator under hard driving conditions
  • Transmission stability – starts, cornering, up and down shifts under loads
  • General drivability - part-throttle, full-throttle, stops, starts, different loaded conditions
  • We are quite satisfied with the early performance of the G37 and are now in the process of installing the planned CARB-stage kit onto the company 370Z 6-speed as well as documenting and developing the step-by-step instructions for the kit. Obviously the manual Z will be a more efficient chassis with less driveline loss, and we’ll post those dynos as they are available. Performance increases of 5-10% are common between manual and automatic vehicles.
    A note regarding CARB: In order for a supercharger kit to be submitted to CARB for approval, everything about the kit must be completely finalized, including instructions, bill of materials (parts list), tuning, pulley size, peak boost, etc. Once that information is looked at, a testing session is granted at an approved facility. Nothing can change from the original bill of materials once submitted. We’re unable (as anyone would) to say that we’re CARB pending until that submission has taken place.
    That being said, we have a long history with gaining CARB approval, including the STILLEN Superchargers for the Nissan 3.5L, 4.0L and 5.6L engines, and anticipate no delays in gaining approval for this system.
    We are flat out in building our first batch of production components, prepared for its release, including the intake manifold castings, machining, supercharger units, components, etc. and are on track for shipped fully tuned supercharger kits in early April.
    There will be stages above the CARB planned kit, with a built-in upgrade path without requiring a compressor change... unless an extremely high horsepower goal is in mind, which we can plan for up front depending on your ultimate goals for your build.
    (And this isn't an official press release.. we'll have that as we finish the proper testing/tuning/drivability.. but that's coming soon.. things will move quickly from this point.)
    Old 03-03-2010, 11:07 PM
      #186
    VossenG37S
    VossenG37S's Avatar
    Very nice job stillen!!!! I'm going to wait for this looks promising !!'
    Old 03-04-2010, 05:44 AM
      #187
    Vu37
    Vu37's Avatar
    I may have to just stack up my money and wait on Stillen to have there kit ready. Keep up the good work!!
    Old 03-05-2010, 08:55 AM
      #188
    philter25
    philter25's Avatar
    I love competition and options. Gives us options to best suit our needs, and keeps pricing in check.
    OBG37
    08-21-2019 09:23 AM
    Team_STILLEN
    Future Models
    13
    09-05-2016 03:13 PM
    bkouba88
    16
    08-21-2015 12:44 AM
    nethole
    08-12-2015 04:08 PM
    Quick Reply: Companies Who Plan On Having A Supercharger For The G37
