Technosqaure Re-ReFlash
#31
![](/images/staff.gif)
when you send in your car for next service, do they reflash your ECU back to stock?
Also, curious to know what your mpg numbers are like?
#32
as for tunning and all that stuff ..
i got a question for anyone who knows the answer ...
is there an o-sirus of our cars ? i know a place where they really spend time on nissan and jap cars.. called japtrix ..
im sure ppl have heard of it... let meknow if there is an o-sirus .. thanks !
ok ok, you're talking about the Osiris UpRev, it's a re-flash program that's use to tune our cars, similar to Technosquares in a way. UpRev is still developing the Osiris for our cars and it should be out Reaal soon.
www.uprev.com
tlon, why didnt ya give Cobb Ap a try that way u could still have a option to go back to stock.
You actually can still go back to stock if you buy Cobb and install then choose to uninstall without saving your current map it will load the stock map that cobb has saved on it
just in case you ever want go back to stock
![thewave](https://www.myg37.com/forums/images/smilies/th_wave.gif)
![Smilie](https://www.myg37.com/forums/images/smilies/smile.gif)
![Big Grin](https://www.myg37.com/forums/images/smilies/biggrin.gif)
He should be fine either way, honestly, just don't say anything and you'll be okay. There shouldn't be any reasons why they have to go and check your ecu, unless theres a check engline light, and even then their obdII scanner will just read and scan the problem like normal without any effects. Bottom line is, most likely they won't know. And he should reset his mpg to see what he gets, thats a good question too.
