perfect RPM to shift from 1st to 2nd?
Old 03-16-2009, 03:49 AM
jambi
jambi's Avatar
hi guys, i'm having problems with shifting from 1st to 2nd gear , it seem that i always get the car to stall for 1 sec before going to 2nd gear.
i usually shift when the RPM is on 7000.
btw , its 08 5AT S version.
thanks,
Old 03-16-2009, 03:55 AM
aliiin
BMW Defector
aliiin's Avatar
are you using the paddle shifters?
are you constantly revving to 7k to shift? that can't be good
Old 03-16-2009, 04:16 AM
jambi
jambi's Avatar
yep paddles
and really ? :/ i usuallly shift before it reaches the RED part.
Old 03-16-2009, 08:46 AM
Callaway
Arm flailing tube man
Callaway's Avatar
stall or lag? a grounding kit is supposed to help with this.
Old 03-16-2009, 09:06 AM
jambi
jambi's Avatar
mmm it takes 1 sec to engage 2nd gear , dont know what u call that
its not that smooth anymore :/ , and whats a grounding kit??
Old 03-16-2009, 09:10 AM
Dimitry6
Dimitry6's Avatar
lmao Listen its not a mt there is no perf every car has a delay on the shifting with the paddle shifters and yes grounding kit should help you in some what but it doesnt mean you will get perf shifts from 1st to 2nd if u really wonna see how your car takes OF then kick it to 4k rpms and floor it 1s its at about 7.1 kick it into 2nd it will switch at 7.5 or 7.6 cuz of the delay but then you will not lag or stall you'll fly Lol if you try it out send me a pm =] let me know
Old 03-16-2009, 09:14 AM
Reed19x
Reed19x's Avatar
It does it on the 5AT. That's just a typical lag with paddles. It's better, granted not by much, with the stick. It isn't as direct to the gearbox as a manual is. As far as shifting...in first on my 5AT, just average driving, i shift between 2-5 depending on traffic, conditions, road etc. Honestly, just listen to your engine. You KNOW how it is supposed to sound right before the shift. Just listen and feel, you'll figure out what's best.For spirited driving/racing at the track...between 5-7 is probably good. No need to redline just cruising around the city.
My solution is to just drive in DS mode
Old 03-16-2009, 09:49 AM
08ivorypearl
08ivorypearl's Avatar
put that **** in ds and let it ride.... it knows when to shift. and if ur racing from a roll do this : for example 20 roll, put it n first and when usmash the gas take it out shifting moe then put it back into ds.
Old 03-16-2009, 10:30 AM
Achilles
Achilles's Avatar
DS mode FTW!
Old 03-16-2009, 10:33 AM
shumby
shumby's Avatar
my car never sees D unless the wife is driving it.
Old 03-16-2009, 04:05 PM
aznutx
aznutx's Avatar
i guess im old, i have yet to go 7k rpm
but i think wut ur experiencing is just electronic lag
Old 03-16-2009, 04:10 PM
pfizzle
pfizzle's Avatar
Ricer......
Old 03-16-2009, 04:22 PM
solopresident
solopresident's Avatar
shift after it hits red line. that is great for motor lol jk
Old 03-16-2009, 04:24 PM
terrycs
terrycs's Avatar
I wish there was a way to get the shift immediately after the paddle is hit.
Old 03-16-2009, 10:39 PM
WhiteG37S
WhiteG37S's Avatar
should've got a 6sp, shift when it bounces of the rev limiter!!!!
Quick Reply: perfect RPM to shift from 1st to 2nd?
