Review Haltech Platinum EMS for G37
We have fit the Haltech Platinum EMS to many VQ35 HR engines including a couple G37s and wanted to let everyone know it is working flawlessly. Everything from normally aspirated to twin turbo setups are all driving nicely This is currently a wire-in only setup, though it is not difficult and full documentation is available from us. We can also provide base maps for most setups to get you running quickly! New patch looms are under development, which will make this the first Plug & Play solution coming in the future.
For anyone not familiar with the unit, the Haltech Platinum ECU is normally offered as a plug and play standalone ems for the 03-06 Nissan 350Z and Infiniti G35. The advanced but easy to use USB-connected ECU Manager software enables the tuner to map sequential fuel injection, ignition timing and cam timing (intake and exhaust depending on what your engine is equip with). It comes with data logging built in, on board map sensor (22psi, expandable to 60psi), factory CAN integration, two-step, nitrous control and much much more.
Haltech Platinum 350Z EMS (on sale through the end of the year)
If you have any questions, please contact Hal @ Injected Performance
leanlikeacello
08-15-2015 02:14 AM
