should i use the vvell easter oil?
#46
I think Nissan should honestly make a price adjustment here.
At least a representative cuting the s**t and setting it straight on what alternative oils are available to the consumer to use that will resolve this entire problem.
I'll never be happy with the purchase of a new expensive car that makes noise like some old piece o s**t car.
Thats why it goes to the dealer and often, even if the door squeaks!
Dealerships in general have always hated me
#47
There have been a number of posts where the update may not have been done properly or completely. Take your car back to the dealer and have them read the software version. If not the latest, have them update the software. Before they give the car back to you, have them read the software version and make sure it is the latest one. If not, they did not properly or completely update the software.
#50
According to the European Patent Application and the Infiniti VVEL Technical paper, the Nissan Ester oil is the only oil which contains a carbon-based additive to reduce friction with the diamond-like carbon coating on the VVEL valve stems. "Only" means there are no alternative oils available.
Nowhere in any of Nissan's or Infiniti's statements does it ever say use of the Nissan Ester oil "will resolve this entire problem".
#51
Okay, let's try this one more time, in case you, or others, never bothered to read any of the factual information on the Nissan Ester oil.
I read it.
And My Mechanic and the Delership Service Manager (Miami Florida - Infiniti SouthMotors.com) said we put regular oil in all the g37 cars default on oil change.
I asked if it was the ester base oil and they said no. And after that he followed up saying you do not need the ester oil. Its only used for the noise issue. Although we recommend it. But you dont need it. He even recommended Mobil1 since they stock it.
The Mechanic told me you dont need it. Underlined. But.. some here are saying the noise hasnt gone away.
For me Im at 3,744 miles going to Dealership tomrrow for first Service.
My car has never made that noise from day one. But I was told because my car came with the ester oil so on next oil change tomrrow I was going to go with Eneos, but no local dealer has it in stock. So for the last time I will go with the Ester base oil and next 2,000 miles I'll go over to Eneos.
#52
Did I miss something in reading that patent application?
Please enlighten me. And btw, what are your credentials to pontificate on this subject, at length, while castigating other forum members in the process?
#53
Excuse me, I did read the link you so kindly posted to the European Patent Application by Nissan. My question is how do YOU know that this particular patent application has ANYTHING to do with Nissan Ester Oil P/N 999MP-5W30EP, which is the topic of this discussion? Or have you just assumed that it is?
The claims in the patent application are repeated in the Infiniti VVEL Technical paper. Nissan's original announcement of the Ester oil referred to a patent application. The description of the oil in the Technical paper is the same as the oil described in the patent application. (The person who directed me to these two documents is an Infiniti employee who told me the European Patent Application is for the Ester oil.)
My "credentials" are an engineering background, a legal background, a participant in a number of automotive related patents (all U.S.), although none oil/lubricant related, and more than 35 years of vehicle manufacturer (including Factory racing) experience, again, none oil related. I have communicated with a few oil company engineers I know about this Ester oil, the European Patent Application and VVEL Technical paper.
Hope this helps.
#54
Based on what you have said above, you can't absolutely conclude that the two are one in the same; you are basically relying on heresay by some unknown "Infiniti employee".
As far as your credentials, I thought that you might be a lawyer--no lawyer joke intended
#57
I did that too, a bunch of **** about nanoparticle coating etc etc. The thing is, I don't know how any of that differs from a nice synthetic oil like Royal Purple. Besides, if so many people "know", why is there no real definitive information on the subjective. If there's so many smart people "in the know" why won't anyone give a simple is this necessary y/n answer
necessary....There is alot of quantified and verifiable information
on what, why and how....yet there is even more opininated
negative remarks from folks who are trying to justify and validate
their beliefs or just claiming that what they've always used is
Just as good and everyone else is stupid....some things
never change. Some just won't bother to embrace the
new technology, so they insult it. While many others
are already over-their-heads with cars they bought
and probably couldn't afford so they show their hate
towards the $12/quart oil that is recommended for it.
I'ts really this simple....Nissan developed a nitrogen free, carbon
impregnated coating that allows them to use newer parts
designs that generate more heat than previously possible.
Nissan also developed a specific oil that uses nano-particles similar to the ones in their DLC that togeather with their DLC coating, greatly reduce valve train friction in middle RPM range....up to 20% reducation.
Their oil improved NISSANS Fleet mileage numbers and reduced CAFE
pollutent numbers....not hard to understand at all.
You just need to decide if it's worth it to you to use it. If you plan
to drive your car 100K and Nissan oil gets you 1.5 extra miles/per
gallon, their oil will save you about 400 gallons of fuel @ $3/gallon
equals $1200 savings per 100K miles of driving ...now you just
have to decide if the extra oil cost is worth it and if you're
car will last that long without it.
#58
answers and references to almost all these questions and more.
....way too much to get into here, but I assure you I did
many hours of research (for myself) and shared it others...
(many there continually gave me a hard time, even though
I was only presenting available information to substantiate
my case) Many don't refuse to understand,, won't read it for themselves
and really just don't want to use it or spend the money on it.
That doesn't change a thing.....until their engines start to
have more and more oil related/sludge and wear issues sometime
in the near future.
#59
Juicy, If you read "the definitive oil thread" on this board you'll find
in the near future.
in the near future.
4DRZ
10-02-2015 10:54 AM
Junchao Sun
25
10-01-2015 01:41 PM
