Official Cobb AccessPORT question, answer, and help thread
Old 03-17-2009, 12:49 PM
  #196
jnguyen
jnguyen's Avatar
i check in those boxes and hit ok. now what
Old 03-17-2009, 12:54 PM
  #197
jnguyen
jnguyen's Avatar
downloading oneclick version
downloading version.txt from http://www.accessecu.com/support/accessport/oneclick/
version= 1.2.0.0-8720
file= 289737675c0cb934887e610a064ff845 *AccessPORTUpdater_1.2.0.0-8720.exe
file= fd5eee73d5ea5ed88ae51b41706a371c *version.txt
checking beta
downloading version_beta.txt from http://www.accessecu.com/support/accessport/oneclick/
version= 1.2.0.0-9080
file= 63e3e8ef9585ddae6065b82815224cdd *AccessPORTUpdater_1.2.0.0-9080.exe
file= 9439bdccc0058f8a33551a89cba1c25e *version_beta.txt
client-side version= 1.2.0.0-9080
server-side version= 1.2.0.0-9080
no oneclick update necessary
connecting to device
using old comms
request device version failed
failed to request device version
error occurred
help
Old 03-17-2009, 12:56 PM
  #198
tristan1334
tristan1334's Avatar
It should take 5-10 mins. to update. You checked the box for beta right? Clear the codes from your ecu then flash it. Stage 1 or stage 2.
Old 03-17-2009, 12:59 PM
  #199
tristan1334
You still have the old firmware for your updater. Download the new firmware then update your AP
Old 03-17-2009, 01:04 PM
  #200
jnguyen
jnguyen's Avatar
this is exactly what happen. I install the updater. Then i plug in my AP and it just randomlly started doing stuff. took about 5 min. Then when it finish i click option and i check both boxes in then hit ok ten it say restart it so i did then when i reconnect it try to update but fails
  #201
G37Rider92649
G37Rider92649's Avatar
Call Cobb, they'll walk you through it step by step, so much eaiser. Here's a main question also, DOES YOUR CAR STILLS START?? If it does you could do this, if it doesn't...
Old 03-17-2009, 01:25 PM
  #202
jnguyen
jnguyen's Avatar
ok Cobb uninstall but now i have Engine Code p0605 and i let it warm up a little then i drove and it drives but like 1-2 mph and it wont let me go pass that. I read the code but it still say service engine soon. So what do i do. Disconnect battery or reflash or what
Old 03-17-2009, 01:41 PM
  #203
jnguyen
jnguyen's Avatar
i reset the code with engine on on position and it comes back. i did it with the car on and it come back. WTH someone help. i cant drive my car
Old 03-17-2009, 01:51 PM
  #204
tristan1334
I cleared mine while engine off but ignition to on position.
Old 03-17-2009, 01:55 PM
  #205
jnguyen
jnguyen's Avatar
i called cobb. they told me to install a map but dont save stock ECU then uninstall it after and it should be fine so right now it installing stock style map then im going to install so hopefully it works. they are thinking my stock map(oem) got corrupted
Old 03-17-2009, 01:56 PM
  #206
jnguyen
jnguyen's Avatar
i did that but it came back so i did while engine on and it came back so i call cobb
Old 03-17-2009, 02:06 PM
  #207
tristan1334
I installed stock style map right away after I cleared my ecu. I have not encounter any problem
Old 03-17-2009, 02:14 PM
  #208
jnguyen
jnguyen's Avatar
some reason everything works fine now except this Airbag belt thing keep poping up above the GAS gauge. idk what it is but it keep blinking. should i reset the battery
Old 03-17-2009, 02:20 PM
  #209
tristan1334
tire pressure?
Old 03-17-2009, 02:23 PM
  #210
peterbanks
peterbanks's Avatar
That is the indicator for the passenger airbag disable. Do you have something light sitting in the passenger seat, that would trigger the weight sensor?
Quick Reply: Official Cobb AccessPORT question, answer, and help thread
