Help A/F ratio with COBB AP?
I am running the cobb access port stage 2 settings with high flow cats. At idle he Air to fuel ratio is a consistent 14 and sometimes bumps up to 15....this seems rather high... At full throttle it dips a bit and keeps alternating between 12-14. I am not that affluently learned in this area and have heard from friends that these numbers seem high. Any input would be appreciated
a high A/F at idle is not that big of a deal. The engine is under absolutely no load. Almost all vehicles have very high A/F's at idle.
Now high A/F's and a engine under load are very dangerous. I know N/A motors can be run a little leaner safely than F/I motors but the sweet spot on F/I motors is usually in the 12.0 to 12.5 range....I would think 13 would be fine N/A...IMO
Sam Rothstein
Just looked at my baseline run and saw that when stock I was at around 13.5 at idle and went down to about 12 at full throttle... So yeah, I think you're a little high IMO...
12.6 to to 13.2 is acceptable for a high performance naturally aspirated car.
Two questions:
1) is the traction control on? If the car sees slip it will reduce power and go lean for a fraction of a second.
2) how and when are you measuring AF? At light load the car will always target ~14.7:1. Under load the AFs immediately get richer.
If you are running high flow cats AND are using an intake your calibration is likely not appropriate. Cobb's current calibrations will not take into account the exta airflow and maf scaling associated with both intake and high flow cats. If you are using both the performance will improve with the soon to be released stage 2+ calibrations.
Also, John Shafer at Cobb in salt lake city and SurgeLine Tuning in portland oregon are offering custom accessport mapping for unique configurations. This is a paid service that allows us to develop totally custom calibrations for virtually any combination of parts.
If you have specific questions feel free to email sales@surgelinetuning.com or call.
Regards
Tim Bailey - SurgeLine Tuning - A cobb premier calibration R&D facility
Slapshot1
09-27-2015 08:40 AM
oct2274
35
08-27-2008 07:37 PM
