Loss of Engine Response
Old 10-26-2008 | 01:12 PM
ajkeence99's Avatar
ajkeence99
I apologize if this has been posted before but I searched and couldn't find anything that matched what I experienced.
I was driving around town the other day and I went through a stop light and turned left to head up a hill and when I gave the car a decent amount of gas it felt/sounded sluggish and didn't have any torque. It felt as though the car went from 6 to 3 cylinders or something. It wasn't only in one gear but was in every gear (I have an 08 G37S 6MT). After a short period of time it just went away on it's own and the car felt normal again. Is this something that has happened to anyone else before? Should I take it in to get checked out?
Old 10-26-2008 | 02:16 PM
PearlG37's Avatar
PearlG37
Yes, take it to the dealer. I had the same thing happen to me and I shrugged it off thinking I got bad gasoline or something. Few days later it happened to the point of my car not even moving. Turns out there is a known problem with a fuel sensor (not sure on the technical details). I had to get it towed to the dealer and they replaced it (under warranty of course). Take my advice, take your car in before you get stranded!
Old 10-26-2008 | 02:56 PM
ajkeence99's Avatar
ajkeence99
Thanks for the reply, that was my initial thoughts too. I figured it was bad gasoline. I bought gas on Camp Pendleton for the first time since I had the car and it did that the next day.
Old 10-28-2008 | 03:42 AM
notsoricer's Avatar
notsoricer
its your traction control! you will see you light flash on you cluster. just slowing down the spin. turn off the traction control on the left side of the column and that wont happen.
Old 10-28-2008 | 07:58 PM
PearlG37's Avatar
PearlG37
No, I completely understand how my VDC works. My experience was entirely different. My car eventually did not start. I had a bad fuel sensor (again, I forget the technical details) and Infiniti had to keep my car for a day to replace it. I'm surprised it wasn't a recall.
I guess it's possible I misinterpreted what you’re describing? If you have your Vehicle Dynamic Control (VDC) turned on, which by default it is on, then when your wheels slip, the car will not deliver power to the wheels. If this is the case, then I would suggest reading the owners manual....
Old 10-29-2008 | 02:44 AM
ranga's Avatar
ranga
This exactly happened to me on a up hill. I raised the rpms and it sounded wrong. I had to stop for a few minutes and then it started and ran fine after that. I went to the dealership after that and the rep told me that if I face the same problem again, they will try to get the same conditions and diagnose it. But then it never gave me the problem again. And no VDC was not on.
Old 10-29-2008 | 04:19 AM
bboysteele's Avatar
bboysteele
It is strange that this happened but no SES light popped up!
xxg00w0
Intake and Exhaust
42
03-18-2021 07:44 PM
gammamotors
44
12-31-2015 12:48 AM
dedmanchan
09-24-2015 11:25 PM
Quick Reply: Loss of Engine Response
