knocking/missing noise from engine when idle
Old 01-29-2013 | 01:41 PM
  #31
jktinen's Avatar
jktinen
After so much BS the dealer finally agreed to do the TSB which ended up being a new short block... will repost in about a week when the part is in.
Old 01-29-2013 | 07:18 PM
  #32
huwee06's Avatar
huwee06
Lucky
My engine knock comes and go so I have no case of having TSB work done
Old 02-05-2013 | 12:12 PM
  #33
jktinen's Avatar
jktinen
mine only happens after driving the car for about 5 minutes, then it is constant untill it cools down. Taking it in thursday for the block.
Old 02-16-2013 | 12:31 AM
  #34
jktinen's Avatar
jktinen
Finally got the new block in. The car makes the same noise. The tech says he cannot hear it. All of my friends hear the noise and my mechanic (not infiniti) hears the noise... My mechanic thinks it has something to do with the engine mount or a sound deadening issue in the car. The noise can only be heard inside the cabin and is definitely coming from the engine... Any insight would be greatly appreciated. I am still under warranty.
Old 02-21-2013 | 05:43 PM
  #35
jktinen's Avatar
jktinen
Contacted the consumer affairs line to try and resolve this. They said take it back to the dealer and have them listen to it again. The dealer keeps saying its normal nose and I am hearing the injectors... Does anybody know if the TSB for the VVEL applies to the 2009 sedan??
Old 03-05-2013 | 12:16 PM
  #36
jktinen's Avatar
jktinen
So I brought my car to a different dealer and they identified the noise as a faulty fuel line dampener. Replaced the part and the noise is gone!
Old 03-08-2013 | 02:46 AM
  #37
deep007's Avatar
deep007
where you getting an tapping noise around 1500 rpm?
vamarris
12-09-2018 12:10 PM
Junchao Sun
25
10-01-2015 01:41 PM
mikysee
09-28-2015 12:18 PM
Slapshot1
09-27-2015 09:40 AM
dedmanchan
09-25-2015 12:25 AM
