Oil Consumption on G37
Old 09-12-2008, 12:26 AM
shabbo
shabbo's Avatar
Originally Posted by Blackjack
No oil consumption problems here and I drive it like I stole it.
Okay... May I don't drive like that, but I do drive it aggressively when safe to do so.
I was at the Dealership today to discuss the Oil Consumption issue on my G since the level indicated about slightly more than a quart consumed in 2000 miles since the last change. (probably more given that it was overfilled and showed full 1500 miles ago)
Anyways, There's apparently a new Bulletin out for the HR engines just a few days ago that requires Ester based oils that run at about $11-12 per quart. Semi Syn oils burn away too fast given the high rpms, compression and temperature.
Probably explains why Motul 300V does not drop in level. Nissan carries an OEM oil that is also ester-based supposedly.
I was told that I will get a free oil-change next time
warpeacelove
09-28-2015 10:39 PM
timc00k
09-05-2015 05:12 PM
Mattlorentzoe
08-21-2015 05:09 PM
cellwoot
08-13-2015 04:27 PM
JakeG37
08-02-2015 12:00 PM
Quick Reply: Oil Consumption on G37
