5at Vs 7at
Old 08-20-2008, 11:02 PM
Gthirty7
Gthirty7's Avatar
5at Vs 7at
any body know whats the big diffrence between them?
besides the 7AT got 2 extra gears lol
Old 08-20-2008, 11:09 PM
The1andOnly
The1andOnly's Avatar
The gear ratios will be closer.
Old 08-20-2008, 11:20 PM
kg37
kg37's Avatar
Yeah what he said. LOL! And it will probably be better on gas.
Old 08-20-2008, 11:35 PM
Gthirty7
Gthirty7's Avatar
any idea how much better on gas it would be?
Old 08-20-2008, 11:38 PM
The1andOnly
It won't be that much. I wouldn't even call it a significant gain in mpg.
Old 08-20-2008, 11:39 PM
Gthirty7
Gthirty7's Avatar
would be any faster?
Old 08-20-2008, 11:41 PM
The1andOnly
No, since you're not adding power.
0-60 times possibly a slight improvement.
Old 08-21-2008, 12:11 AM
amoney805
amoney805's Avatar
smoother shifts, and probably an extra 1-2 mpg
Old 08-21-2008, 12:57 AM
Achilles
Achilles's Avatar
yeah, probably extra 1-2mpg which is better than not having the extra miles add up in savings but in the short-term, not much of a gain........ No power added though...... still the same....... closer gear ratios which means it will probably cruise at 2k rpm instead of 2200 which results in slightly better gas mileage......
Old 08-21-2008, 01:34 AM
nonsensez9
nonsensez9's Avatar
faster shifts?
Old 08-21-2008, 01:40 AM
tfmbigdog99
tfmbigdog99's Avatar
Location: Where the kids are high and the grades are low. NYC
Faster as in you'll get to second quicker than you will now, because the MPH range in each gear has been decreased. But your not going any faster, if that makes any sense.
Old 08-21-2008, 12:38 PM
LudwigB
LudwigB's Avatar
Crusing at 80mph will be at around 2700rpm
Old 08-21-2008, 01:37 PM
chasemyaccord
chasemyaccord's Avatar
If the gear ratios are assigned more efficiently, why wouldn't the car be faster? It wouldn't be by much, but nevertheless it's does make a difference, no?
Old 08-21-2008, 01:58 PM
Achilles
Achilles's Avatar
on a 7AT, 2700rpm at 80mph doesn't seem right.......
Old 08-21-2008, 03:09 PM
Tarkus
Tarkus's Avatar
Overall performance increase because the engine will be able to stay within a more optimum hp/torque curve more often. Revmatch downshifting and quicker paddle shifts a plus on the coupe. Not sure the sedan will have the added features on its 7AT.
Quick Reply: 5at Vs 7at
