Got ECU Reflash/Dyno Tune at Technosquare
Old 09-07-2008, 02:32 AM
  #46
VRG37S
VRG37S's Avatar
So with a reflash there would be no need for me to keep my BLITZ T.C.???? Any help would be greatly appreciated thanks a lot
Old 09-07-2008, 11:46 AM
  #47
Buddy Revell
Buddy Revell's Avatar
You can keep it. I asked Tadashi and he said that he can keep your throttle response stock when he does the reflash so you can use your Blitz unit to control it. Normally, he adjusts your throttle response as part of the reflash.
Old 09-07-2008, 11:55 AM
  #48
Buddy Revell
Originally Posted by amoney805
The tq and hp loss under 3k hurt my feelings.
I know this might not be accurate, but using my trusty "butt dyno", I noticed something. I occasionally get SES lights due to my high flow cats, so I sometimes have to reset my ECU (I use the pedal technique). Immediately after resetting the ECU. I notice a bit of sluggishness below 3k. However, after driving around for about an hour, the ECU seems to adjust and the engine seems to get stronger under 3k.
Old 09-07-2008, 06:06 PM
  #49
VRG37S
VRG37S's Avatar
I'm still kinda skeptical about this mod...
Old 09-07-2008, 06:10 PM
  #50
J.Oh
J.Oh's Avatar
how? ecu reflash is one of the best things you can do after you have a bunch of bolts on
Old 09-07-2008, 09:28 PM
  #51
bboysteele
bboysteele's Avatar
Or even if you don't have other bolt on mods. A ECU reflash is usually the best mod you can get on a NA car.
Old 09-08-2008, 09:37 AM
  #52
Buddy Revell
Why would you be skeptical?
Old 09-08-2008, 07:35 PM
  #53
VRG37S
VRG37S's Avatar
Cause I had heard they havent burned and ruined some ecus on 350s and g35s so I dont know if I want to take that chance
Old 09-08-2008, 08:23 PM
  #54
Buddy Revell
Where have you heard this? I've read many posts on My350Z and G35Driver about Technosquare and have seen a very high satisfaction rate with them.
Old 09-08-2008, 08:40 PM
  #55
tlon19
tlon19's Avatar
anyone anyone confrim if the dealer would be able to detect the reflash?
Old 09-09-2008, 12:46 AM
  #56
Dieseldoug22
Dieseldoug22's Avatar
According to Tadashi the dealer would have to be able to read the actual code of the ECU to see if it was reflashed. And the chances of that are slim and none. You can't hardly get a good car wash or oil change without something being jacked up.
OneSickBlackG
01-06-2016 08:49 AM
Raffay Khan
Intake and Exhaust
09-14-2015 10:47 PM
dlc1988
09-02-2015 09:40 AM
Quick Reply: Got ECU Reflash/Dyno Tune at Technosquare
