Stillen Crank Pulley
#107
I received my Stillen Crank Pulley (UR Pulley-OEM size) yesterday and will install Saturday morning. I'm getting a dyno prior to the install, then 2 afterwards at Engine Logics in Houston, TX. I won't be able post results until Monday or Tuesday of next week. By the way, it was great meeting everyone at the G35/G37 meet on the 23rd, and hope we can have another meet in the next few months.
#109
yea, he's talking about the "Time vs. Speed" chart. It should automatically pull this info, the dyno operator will simply click an option to print this option as well. As said, this will probably be where the most noticeable differences will be with a mod like this.
#110
I was just showing you what UR says their pulleys do, I'm not bullsh!tting you guys with my claims because I read I should be faster, my car is faster!! and revs quicker!! If YOU remember the dynos showed hp gains for injens, just not the amount promised. Did I say I gained what UR claims??? NO!! I said I feel that I gained hp, the amount is unkown until Friday. Until then you WILL remain an idiot, and the resident D-Bag for your comments and lack of common sense. "When it comes to a lighter pulley it does not increase horsepower or allow you to rev quicker. All your doing is making your car lighter " That comment earns you a Gold in the Special Olympics
#111
Now calm down Az to the g ... they make pads for that bleeding ! The reason for my comments is that on my 06 350z I bought the whole ur kit . Also had it dynoed and guess what ???? It did not rev quicker and there was no hp increase . Now moving forward there is a member on my 350.com with a hr engine .. Now , Now I know there not the same being the only difference is that the g37 has a bored out engine and vvtel so how possibly could they both be sooooooo different ?? guess what his results are ? The same thing !! Nothing !!!
#113
If the Cobb AP comes out in the next week or two then I will be using that to fix the throttle control and other things.
#116
I really want a pulley now, thanks everyone!!!
Just noticed on Stillen's site, they're showing a lightweight flywheel now to, which would have the same effect as that pulley change but probably on a little larger scale.
#117
Have you checked the JWT flywheel that they have available for quite some time now, and I'm sure that Andy at HPAuto can get for you?
I prefer JWT's over Stillen's anyday. Remember, JWT just work and dedicate time and reasearch to get best Nissan parts you can find, sometimes even better than OEM according to some people that have tried them.
