nitrous ne one???
Old 06-05-2008 | 11:33 AM
08ivorypearl's Avatar
08ivorypearl
nitrous ne one???
ok so i was talking to my pops and i told him how slow my car is... hes oldschool, he said to spray 100 shot in it. he said if his datsun 280 could hold a 150 shot my car can easily hold 100. gimme some feedback/advice. and if ne one knows the correct jet sizes for a wet shot lemme know!!!!
Old 06-05-2008 | 11:37 AM
SOLISIMO's Avatar
SOLISIMO
I wouldnt do it, you cant always have the fastest car out there I have an 89 mustang thats a quarter mile track car that has spray but not on a luxury coupe, just my opinion
Old 06-05-2008 | 11:39 AM
Kidcane's Avatar
Kidcane
Florida G Club
^^I concur. Not sure how long your nice G will hold up with spray. Does not seem worth it to me.
Old 06-05-2008 | 11:41 AM
08ivorypearl
ye i have a 2003 mach1 on bottle also but its on a 250shot. i dont think 100 shot would hurt. especially if its a wet kit.
Old 06-05-2008 | 11:43 AM
SOLISIMO's Avatar
SOLISIMO
Ok then do it
Old 06-05-2008 | 12:28 PM
madmikeg37's Avatar
madmikeg37
High compression Motor & Nitro = Blown Engine.
I don't think the 240 z & our car has even close to the same compression.
I was told nitro is a no no on our g's.
Old 06-05-2008 | 02:54 PM
Infinite G37S's Avatar
Infinite G37S
100 is not that big of a shot, although with the high compression it would be a gamble dude, unless its under warranty and you blow something up and can hide any and ALL evidence of the squeeze, I would just be happy with what you got!
Old 06-05-2008 | 04:01 PM
fireboy's Avatar
fireboy
for sure i agree not a good idea if you want power turbo it.... i did
Old 06-05-2008 | 09:38 PM
Mr_Ryte's Avatar
Mr_Ryte
How fast do you need your G to be?
Old 06-05-2008 | 10:21 PM
NJKSC27's Avatar
NJKSC27
i love a nice wet shot
Old 06-06-2008 | 01:03 AM
shmad's Avatar
shmad
found these on the web from many different sites:
QUESTION Can I simply bolt a nitrous kit onto my stock engine?
ANSWER Yes. NOS manufactures systems for virtually any stock engine application. The key is to choose the correct kit for a given application; i.e., 4 cyl. engines normally allow an extra 40- 60 HP, 6 cyl. engines usually work great between 75-100 extra HP, small block V8’s (302/350/400cid) can typically accept up to 140 extra HP, and big block V8’s (427-454) might accept from 125-200 extra HP. These suggested ranges provide maximum reliability from most stock engines using cast pistons and cast crank with few or no engine modifications.
QUESTION Can high compression engines utilize nitrous oxide?
ANSWER Absolutely. High or low compression ratios can work quite suitably with nitrous oxide provided the proper balance of nitrous and fuel enrichment is maintained. NOS kits are used in applications from relatively low compression stock type motors to Pro-Modifieds, which often exceed 15 to 1. Generally, the higher the compression ratio, the more ignition retard, as well as higher octane fuel, is required.
from what ive gathered a 75 wet shot would be safe.
and i dont understand why some others say boost is better than nitrous solely based on the compression...u can damage ur motor just as bad w/ too much boost just as if u had to big of a nitrous shot.
Old 06-06-2008 | 06:05 PM
JLai's Avatar
JLai
100 shot shouldn't be a problem as long as its wet.
Old 06-06-2008 | 10:40 PM
bboysteele's Avatar
bboysteele
I have thought about doing this just not sure yet. It is a good way to get cheap/reliable power and as long as you don't go overboard and the install is corrent, you shouldn't have any issues. Anyone who says this is bad for the engine and you will have additional cost is not entirely incorrect BUT there is cost involved whenever you add additional power like this. Personnelly I would say this is safer and cheaper to do than to Supercharge or Turbo your car. If it is done right and you limit the shot, I wouldn't worry.
Old 06-07-2008 | 01:51 PM
08ivorypearl
im looking for quick easy power. not only tha but compare 500 dollars to 5000 and nitrous is def the better buy. no offense.
well find out on wed.!!!! i already baght the kit at a local shop. 2 foggers one nos big shot silenoid capable of 250 hp(im only doing 100) and a fuel silenoid. ill be posting dyno vids next week when we strap the car on.
not too fast, i just want a bit more hp. like 100. lol. and the tq gains are gonna be nice too. that 40mph roll on my car is gonna be dnagerous!!!! IM CALLING OUT ALL THE CHIPPED 335s!!!!!!!!!!!!!!!!!
Old 06-07-2008 | 02:17 PM
Kidcane's Avatar
Kidcane
Florida G Club
This should be interesting. How many miles on your G?
