How to get rid of Check engine light?
I recently installed some Fast Intentions test pipes on my G37 and am looking for a way to get my check engine light to turn off. If I could get some guidance I'd appreciate it. Thanks!
Try this (from Motordyne: http://www.motordyneengineering.com/manual.pdf )
ECU Accelerator Pedal Reset Procedure
Note: Timing is critical for this to work!
1. Turn the ignition switch to on. Dash gauges lit. Don’t start the engine!
2. Wait 3 seconds.
3. Fully depress and release the accelerator pedal 5 times within 5 seconds.
4. Wait 7 to 10 seconds.
5. Fully depress the accelerator pedal for ap
indicating Diagnostic Test Mode II (Self-diagnostic results) has started.
6. Release accelerator pedal and wait 5 to 10 seconds.
7. Fully depress the accelerator pedal for 10 seconds. At this point the check engine light should change to blinking slowly
indicating “Erasing ECU Memory”.
he accelerator pedal and turn the ignition switch to off. 8. Release t
9. Restart the engine. The check engine l
Note: If the check engine light doesn't blink as described in steps 5 & & 7, then the ECU isn't reset.
* If above didn't work, disconnect the battery negative and pump the brake t
foolproof as long as all ECU control parameters are within their normal ranges.
2. Wait 3 seconds.
guys dont bash if you arent a veteran of modding vehicles. buy a mechanical o2 sensor bung. screw into oriinal o2 sensor location as a spacer between o2 sensor itself and exhaust. it raises the sensor out of the exhaust stream causing it to sense less oxygen. it worked on both my sti and evo
test pipes
the ecu looks at the rear o2 sensors to see if the cat.converters are above 70% efficiency, you can clear the codes but as soon as the ecu runs the monitor test the check engine lite will be back on!
![7](https://www.myg37.com/forums/images/smilies/7.gif)
