All About VVEL
Old 03-27-2008 | 03:26 PM
  #31
cartman13's Avatar
cartman13
Originally Posted by OPen Class
Well, BMW had to twin turbo to get 300 hp out of their 6 cyl. We get 330 without the added risk/heat/$$ associated with twin turbos.
Not bad numbers IMO.
I read an article saying the G37 actually gets 3mpg worse than BMW. While I love the G37 engine, i don't see how efficiency was part of the equation.
Anytime you are running 3mpg less than a twin turbo engine... it's hard to say efficiency was high up in there in priority....
Old 09-06-2008 | 04:17 AM
  #32
DanMardik's Avatar
DanMardik
PDF on VVEL technology
Might be a little confusing on the technical side, but a good read none the less.
http://www.nissan-global.com/EN/DOCU...0713VVEL-e.pdf
Old 09-06-2008 | 04:19 AM
  #33
DanMardik's Avatar
DanMardik
ok, i just noticed this may be a repost. Consider this a refresh, or a good read for those who haven't seen this quite yet.
Old 09-06-2008 | 04:27 PM
  #34
hgunner's Avatar
hgunner
Wow, Way more complex in operation than VTEC. Looking at the PDF it shows a Link (either a belt or a chain?) inside the VVEL from the input to control shaft? Is that for each intake valve? Wonder what the link is made of (no information in the service manual)?
Service manual says if any part of the VVEL Ladder assembly (most of the mechnanical parts to the VVEL and actuators/links ) is out of adjustment the VVEL ladder and complete Head needs to be replaced as one unit (that would be expensive piece!) . Hope it is a reliable design...
Anybody have any more information this?
Old 09-06-2008 | 06:31 PM
  #35
vINCe_Inc's Avatar
vINCe_Inc
repost indeed. but its a good read and very interesting.
Old 04-21-2010 | 02:11 AM
  #36
G37Sam's Avatar
G37Sam
<object width="480" height="385"><param name="movie" value="http://www.youtube.com/v/lY9L8hoVPRU&hl=en_US&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/lY9L8hoVPRU&hl=en_US&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>
Old 04-21-2010 | 02:12 AM
  #37
G37Sam's Avatar
G37Sam
Low Lift:
High Lift:
Old 02-07-2012 | 06:08 PM
  #38
kingdavid's Avatar
kingdavid
The reason BMW went TT is because it was a more cost effective way to get reliable +300hp than creating more of the older M engines. Keep in mind technology had advanced in the time between the 335i and the old M. Additionally the 335i's power-core was put together in a hurry, hence all the issues it had (check bimmer forums around when the 335i came out) and heres why
BMW got wind that Lexus was coming out with a 300+ hp entry level luxury sedan, something BMW, or any other luxury brand (Mercedes excluded) for that matter, has never had (to my knowledge) What they didnt know is wether that measurement was at the wheels or the crank and how much over 300 horses the vehicle would actually be.
At the time BMW only had the 330i Which had 258hp. Being the "ultimate driving machine" BMW couldn't have a JDM car on the market that had more HP than theirs so what do they do? THROW TWO TURBOS ON THERE!
Now, the N54(335i/xi) is completely different than the N52 (330i/xi other models) but it's diferent in the ays that make it easier to produce quickly and efficiently ( Aluminum block instead of magnesium, almost exact same fastening points for accessories as the n52 etc.) and while the designes ARE different they are also very similar.
Because bmw had no idea how much over 300hp the 2gr-fse (is350 engine) would have, they built the engine and FI setup to allow for a hp boost allowing them to uprgrade the model with nothing more than a retune to balance out their competitor. Just bring your car in and BAM more hp, they even offer that now for an inflated price.
So to answer the question as to wether BMW HAD to go FI to get 300+ hp...no. But they had to design a whole engine just to compete with JDM. But for that, the 335i will be competitive against newer JDM models for a while save for maybe the new infiniti that's putting down 360 AND is a hybrid which adds something else to the table.
Just thought I'd put that out there.
Old 11-28-2014 | 01:18 PM
  #39
RadioFlyer's Avatar
RadioFlyer
Originally Posted by G37Sam
Low Lift:
High Lift:
I know this is an old thread, but maybe now that you guys have had some time with this engine, do you know more about what that "Ball screw shaft" does? It's a static setting, so would it be the same thing as degreeing a cam? As in, if you set that screw say, +5* advanced, then the whole sweep of valve timing will be whatever is mapped in the ECU table, PLUS 5*?
Old 03-17-2015 | 04:33 PM
  #40
Herostar's Avatar
Herostar
Does anyone have an updated link?
reachout
General Tech Questions
38
06-27-2020 12:35 AM
xnick101
Intake and Exhaust
18
09-16-2015 12:02 AM
indyn
04-19-2011 11:34 PM
needsoju
11-11-2009 07:41 AM
digitalis
07-16-2009 12:36 PM
Quick Reply: All About VVEL
