GT Motorsports: G37S VHRTT, GTM HR Turbo Kit, FCon VPro, Stock Block Testing
#376
GTM is selling the g37 now for like 100g's maybe thats a mistake on the website but thats whats stated
look http://gtmotorsports.com/car.php?vehicleid=17
#379
Not back yet, but so close it's killin' me. I was told about 2 weeks on the outside as of yesterday. They are fixing the boost creep by switching to slightly larger turbine housings on the turbos. The HR apparently dumps a huge amount of exhaust near redline giving the internal wastegates some trouble at high RPM.
#382
did the ever get a new clutch installed into that car and push it father? Also what did the determine was the cut off as far as power is concerned with this stock block? 550-575whp possible with the proper supporting mods?
#383
Hey guys, new member here.
The VQ37VHR will be in the new 370Z correct? How can you boost an engine with a CR of 11? That just seems unheard of to me. I mean, is the rotating assembly forged? Is 8 psi considered safe? What is the max you would want to put on the stock block?
Thanks!
Thanks!
#384
I don't think it's possible to put a real number on it because damage occurs over time. 1000WHp on the AT will work forever as long as one does drive with a lead foot, yet 400WHp on the AT may only last 6 months if the car is tracked and driven hard.
In my case, there is no advantage to building up the AT internals now, or later if/when it starts slipping.
#386
Not back yet, but so close it's killin' me. I was told about 2 weeks on the outside as of yesterday. They are fixing the boost creep by switching to slightly larger compressor housings on the turbos. The HR apparently dumps a huge amount of exhaust near redline giving the internal wastegates some trouble at high RPM.
#388
Not really sure what the limits are on the AT transmission yet. I have a transmission cooler and a valve body upgrade on mine. I was told my car will easily chirp 3rd gear now.
#390
I've been driving it. All I can say is
Blitz boost controller works great. Low setting of 0% lets me run at 5-6 psi which is still enough power to spin the 285 tires through 3rd gear. The shift kit has been solid. High setting takes it up to about 9-10 psi for 470WHp as dynoed earlier. No more creep with the bigger turbine housing. No noticeable lag and very smooth acceleration all the way to redline.
From a dig, there is simply no way to get good traction with the VDC off. I noticed some noise coming from my front suspension so I took it to Riverside Infiniti to get checked out. Mike was working that day so I let him take my car out:
http://g35driver.com/forums/lounge-o...vq35hr-tt.html
