Did My First Oil Change Today
I got off of work early today so I figured I'd go ahead and do the first oil change on my G37.
My car hit 1200 miles today and still had the factory oil/filter. I also did a hard break-in.![Drivingskid](https://www.myg37.com/forums/images/smilies/drivingskid.gif)
It took longer than expected because I had to take off the plastic engine cover from underneath the car that was held in place by (16) 10mm bolts and (3) panel clips![Eek3](https://www.myg37.com/forums/images/smilies/eek3.gif)
Other than that, it was pretty easy changing the oil on the G. The oil filter and the oil pan bolt were pretty accessible once the cover was removed. Wasn't very messy at all.
I used a SuperTech oil filter and 5 1/8 qts of Valvoline 5w-30 conventional oil. I got both from the local Wal-Mart.
I'm going to change my oil again when I hit 3750 miles, and then every 3750 miles after that, using conventional oil and probably a Purolator oil filter. I'm also starting a maintenance log and saving receipts for any oil/filters that I use.
And to all the synthetic oil nuthuggers, there's really no point in using synthetic oil if I'll be changing every 3750 miles anyway IMHO
I do my own oil changes rather than taking it to the dealer or paying some yahoo at the JiffyLube to do it.![7](https://www.myg37.com/forums/images/smilies/7.gif)
Besides the savings of doing it myself, it's a peace of mind thing. I know it's done right and just the way I want it done. I don't trust mechanics with my baby![Stick Out Tongue](https://www.myg37.com/forums/images/smilies/tongue.gif)
Happy motoring!
Happy motoring!
![Driving](https://www.myg37.com/forums/images/smilies/driving.gif)
![](/images/staff.gif)
People have different views of when it is best to do the first oil change. Whether you change it early or at the recommended interval, it won't hurt anything.
Until then, I'm going to keep doing what I do
![Smilie](https://www.myg37.com/forums/images/smilies/smile.gif)
You might want to do a little research on the benefits/differences between convention, semi-synthetic and full synthetic oils. You will see there are difference and "points". They may not be important to you or worth your money. But, there are "points" in using full synthetic or semi-synthetic oil even with 3,750 mile change intervals.
I plan on doing my first oil change @ 3750 mi...im at 1100...I want to do a high end petroleum motor oil (i am changing every 3750 miles anyway) and either a top end purolator or Mobil 1 filter....
Can you guys give me some input as to....
What motor oil(s) is(are) best? (eg different tiers of valvoline, pennzoil, castrol, etc etc.)
Also I live in Michigan where we have 4 seasons and what weights of woil do we use and when...Like 5w-30 vs 10w-30 etc?
Please let me know....
Show me solid proof like used oil analyses of conventional vs synthetic.
I plan on using either Royal Purple or Amsoil in my G37 (both full synthetic)... I've heard top reviews on both. I used Mobil 1 synthetic in my 05 G35 and was very pleased with it (with Mobil 1 Filter).
Filter wise, I'll probably use the Amsoil EaO Filter. The tough thing is that Amsoil and Royal Purple are tough to find at retailers.
Concerning your used oil analysis, please contact the companies who perform oil analyses. They will show you what they have learned.
Oil company engineers will tell you never use a higher number at either end of the suggested weights. In other words, Nissan specifies 5W-30 for the G37. Do not use a 10W-30 or a 5W-40. Hope this helps.
So 5w-30 is recommended whethere rain or shine, 100 or 25 degrees out? Okie...I will probably go with that then. 5w-30 AMSoil or Mobil 1 synthetic...with Mobil 1 or high end Purolator Filter.....Don't some peopel say that it's better to do 2-3 conventional motor oil changes first to break in the oil system and all before introduced the more slippery and "better flowing" synthetic? Is that a myth or true? Because if it's a myth I would love to get synthetic AMSoil or Mobile 1 in her right away at the first 3750 change...
Unless anyone has anything else to add....?
The Purolator PureOne seems to be a solid Oil Filter & top of the line, might as well pay a few bucks more than what the premium plus costs...98% filtration
PART NUMBER: PL14612 if anyone is interested....
I cant find that Mobil 1 makes an oil filter for the G35/G37 (which I am pretty sure is the same filter size)
I would rather run synth for longer intervals than dino on shorter intervals. Plus there's not as much waste and time spent under the car. Been doing my own oil changes for years and we have a tribologist in the family.
I would stay away from Purolator filters. And Fram. Search oil filter tests and read for yourself. That before someone says 'prove it'. Often times, OEM filters are the best option.
My consensus is this...
Royal Purple, AMSoil, or Mobil 1 synthetic oils with either a Mobil 1, Napa Gold, Wix, or Purolator PureOne oil filter or is a GREAT matchup for our G's....
For all you synthetic, engine efficiency longetivity nuts out there....All you leasers probably will go to some 20-minute oil change or dealership Im guessing....
