Effects of using regular gas in G37??
Old 08-27-2007, 04:53 PM
Callaway
Arm flailing tube man
Callaway's Avatar
Wait till you need new brakes....(especially if you have the Sport package).
Callaway is offline
Old 08-27-2007, 05:32 PM
pensfan
pensfan's Avatar
An 11.0:1 compression ratio? Highest octane I can get at the pump, please.
pensfan is offline
Old 09-07-2007, 06:04 PM
ABQG35c
ABQG35c's Avatar
Originally Posted by SeismicGuy
This subject always cracks me up, especially when it comes from someone who has opted to obtain a performance car. Just do the math and see if your concerns are warranted. Assuming 30 cents more a gallon for premium (probably not really that much) and assuming you drive 10,000 miles a year and get 20 mpg, that comes to 500 gallons of gas. So 500 gallons at 30 cents more per gallon comes to $150. Do you really want to downgrade the potential performance of you car so that you can save $150 per year?
Doug
You know what cracks me up too? Is when people asking this question... just got done paying $40k+ for a vehicle, and are worried about 2-3 dollars extra to fill up with Premium over Regular.
The car is Premium Only! It was tuned for Premium only, use Premium Only!
ABQG35c is offline
Old 09-12-2007, 11:01 PM
shumby
shumby's Avatar
WHY? not asking to be "smart". I just don't know.
shumby is offline
Old 09-13-2007, 05:11 AM
pensfan
pensfan's Avatar
The higher the compression ratio (and 11.0:1 is definitely on the high end), the greater the possibility that detonation ("engine knock") might occur. Detonation occurs when the air/fuel mixture ignites suddenly rather than gradually. Imagine normal combustion as the flame gradually spreading throughout the unburned mixture. With detonation, some of unburned mixture is hot enough and at a high enough pressure that it can spontaneously ignite, before the flame ever reaches it. This causes the pressure to rise even higher and a wave to form and bounce around in the cylinder, resulting in a pinging noise, interruption to the combustion cycle, and greater stress on the engine itself.
This is where the octane rating comes in to play. The higher the octane rating, the more resistant the fuel is to detonation. I'm a little fuzzy on the actual how/why of this part, so hopefully someone else can chime in.
pensfan is offline
Old 09-13-2007, 05:15 PM
shumby
shumby's Avatar
^^ Thanks makes sense now.
shumby is offline
Old 09-13-2007, 05:38 PM
likwidfuzion
likwidfuzion's Avatar
Explanation of octane rating by howstuffworks.com: http://auto.howstuffworks.com/question90.htm
likwidfuzion is offline
Old 09-13-2007, 06:12 PM
finagle69
finagle69's Avatar
god i love that site.
finagle69 is offline
Old 09-19-2007, 02:49 PM
PlatinumGish
PlatinumGish's Avatar
Originally Posted by t-bone1924
Thanks for the responses. If the G requires it, premium it will get!
Saving money was not the main issue for my question--wasting money was. I have owned several other high performance cars, all of which were far more expensive than the G37, which called for premium fuel. In all cases, regular did the job just fine albeit a little less mileage per tank, mainly because the computer adjusted for the lower octane.
Man, I couldn't help but post a reply to this.. it erk's me when someone purchases a car that performance oriented, (like the G) and wants to pinch pennies when it comes down to maintaining it. You paid for a 40k car that requires permium gas.. you should have accepted that prior to making the purchase. I dont really see how your really saving that much money if you realize that you end up getting "a little less mileage per tank." So the maybe, ummm, $150 a year that you would be saving if you actually got the same mileage as using premium turns into a $75 - 100 savings. In return, you get a car that doesnt perform up to the way it was built to and possible ping and knock problems in the long run... then you end up spending even more money later on to fix that.. lol.. Ok, lemme stop.. I can go on and on.. I just don't understand that way of thinking.. lol
PlatinumGish is offline
Old 09-19-2007, 07:56 PM
Memphoman
Memphoman's Avatar
running reg gas is like drinking Coors light...WHY???
Memphoman is offline
LexiG37 (04-29-2015)
Old 09-19-2007, 10:26 PM
ABQG35c
ABQG35c's Avatar
Best comparison yet to date! Memphoman FTW!
ABQG35c is offline
Old 09-19-2007, 11:04 PM
KAHBOOM
Super Moderator of Pwnage
KAHBOOM's Avatar
I am with you.. but I think the OP was not thinking of it like that.. He was just askign if it was "required" or "recommended"
LOL
KAHBOOM is offline
Old 09-20-2007, 02:00 PM
ABQG35c
ABQG35c's Avatar
Well the way I see it is, on any Premium gas vehicle, on the gauges, it says PREMIUM FUEL ONLY... I just don't get why a question like this would arise on a vehicle of this type...
ABQG35c is offline
Old 10-09-2007, 07:18 AM
  #29
Mad Paradox
"No Compromise"
Mad Paradox's Avatar
Not to be mean but I would like to see someone post something up saying that they filled up the G with regular and destroyed their engine. Turn that post into a sticky and relate back to it whenever someone asks...
Mad Paradox is offline
Old 10-09-2007, 04:57 PM
  #30
The Old Man
The Old Man's Avatar
The main reason for the premium is the new 3.7 motor is 11.0-1 compression ratio (up .4).
When you run a comp. that high, you need to run premium fuel.
The Old Man is offline
Quick Reply: Effects of using regular gas in G37??
