G37S 6MT shifter stick vibration?
Hey guys,
Not bagging on the G37 of anything (I simply love the car!), but when I test drove the 6MT, I noticed a crazy amount of shifter vibration. When at idle, you can totally see the stick vibrating like crazy, as well as when you have it in gear and take your hand off the shifter. You can also totally feel it too when your hand is on it. While it is not a huge problem, it just makes the luxurious interior look cheap to see the shifter bouncing around. Heck, even low-end Honda's don't vibrate at all!
I know this is a "problem" that the G35C used to have. Has there been a fix for this in the past?
Have you guys noticed the same in the G37s? Does it seem to bother you guys as much as it does me?
I notice it to when the car was stop but not engaging it into a dfferent gear. G35 does it so does the 350z but the 350z vibrates to much. Im sure it has to do with the drivetrain. I also wonder does it have to do with the fact its rear wheel drive and you said Hondas dont do it maybe its beacuse its front wheel drive. not sure though
Who cares? You shift and then you take your hand off the shifter, its just vibration. Its no big deal, its just vibration. I like the vibration, I can feel the car through my hand.
I actually prefer vibration. I currently own a 6MT 350Z which definitely has a lot of vibration in the shifter. When I test drove the 6MT G35 sedan, I felt so disconnected from the car because it had no vibration at all. The vibration just makes me feel more connected to the engine somehow. I think since the G37 is a sports car (like the Z), they left in the vibration on purpose. The sedan version had 0 vibration, so I'm sure they could take it out if they wanted to.
It's like having your hand on the pulse of the car. A great deal of that sports car feeling is "connectedness" to the road and the car. I would miss the shift vibration. That vibration is like having your arm around your favorite girl. Hopefully, the G37 moves like a mature woman.
I found much less vibration with the shifter this time around. The engagement is so smooth it's silly. This shifter itself is also a little different shape, but I find it more comfortable than the G35.
I just test drove a 6MT IP last night. I was looking forward to comparing it to the 07 Sedan. The engagement on the G37 is sooo much smoother and engagement is lower, unlike the Sedan which had a awkwardly high engagement...seemed like you knee was half way to your chest before you can feel the clutch engage. Made you feel like you were doing the "Heisman" pose! With the coupe, shifting through gears is very easy, no vibration that seems to be out of the norm.
Funny though...when I ended my test drive, the salesman had me drive it up a steep ramp to their parking structure...which I did. At the top, their lot was filled with cars. He told me "if you don't feel comfortable parking it, I'll take it from here." I was like "ok...you take over." So he gets in and stalls twice! heheheh.
