Tuning
Tuning
So i went to Performance Motorsports, located in Smithtown, NY, had UpRev Tuning done to my 09 X Coupe 7AT.
On the baseline, i pulled 282 hp and 235 tq to the wheels, that was just my car with the Q300 and the Gen3's on it. They ran a total of 7 pulls on my car before the finalized tune kicked out 294 hp and 248 tq, of course this is in 25* weather. The "weather corrected" number puts the car at 277 hp and 225 tq. apparently thats what my car will be more like during summer months. Definitely a noticeable difference in the way the car performs!
I have to say though, the guys at Performance Motorsports were pretty awesome. I got to chill with them, watch them do all the pulls and adjust everything. Unfortunately the Berks HFC's didnt make it in time for the tune so i'll be going back to have them installed in a few weeks, hopefully with some Hotchkis sway bars. Getting the tails painted too, they got a body shop that does some pretty sick work too. ANYWAYS just wanted to say anyone out on the Island or located near the Island whose considering a tune, should definately check out this shop. Highly recommend it!! ...and the dyno pulls from today with the weather corrected numbers!
![](http://i733.photobucket.com/albums/ww333/Romulus1/DSC00845.jpg)
and on this topic has anyone run a bone stock X Coupe 7AT on a dyno or know about what it pulls??
baseline and after gen 3s
https://www.myg37.com/forums/intake-...fter-dyno.html
after HFCs, cat back, and tune (with dyno video)
https://www.myg37.com/forums/intake-...n-x-coupe.html
Wait, so after correcting for weather you lost power? Doesn't sound like a good deal at all. Also, pleased post up what your gains are after HFCs, no one has compared this specific combination yet, and to my knowledge it would be an original contribution to the forums.
Good numbers!
Yes, this is a common upgrade path.. we've had a lot of customers that have installed our Gen 3's, CBE and HFCs to see ~50hp at the wheels, and UpRev is a great solution to dial everything in on the tuning side. Not huge HP gains with the tune, but dials in a specific car to maximize all of the parts to that specific car/ECU..
and i am very happy with my total results, from what i understand, yes, i gained just under 50 horse from the intake the exhuast an a tune and as josh put it, it maximizes your vehicles output. now that its working optimaly/properly i cant compare a HFC's gain too and see what they really look like. i will post it at the end of this month, i go back on the 28th to have them instlalled and retuned if necessary!
Correction factors don't make you lose power. They simply adjust the numbers on the dyno graph by multiplying the final whp number depending upon the current weather conditions at the time of the dyno run compared to "ideal" weather conditions. Depending upon which correction factor was used, "ideal" weather conditions would be something like 25C ambient temp, 0% humidity, etc.
For example, if it was 40C outside with 90% humidity, the final whp number would obviously be less than if it was 10C and 0% humidity. Therefore, if the dyno run was done in a hot summer day, the reading would be multiplied by 1.1 for example to make up for the less than ideal weather conditions. On a day when the ambient temperature is lower than ideal (such as 10C), the reading would be multiplied by 0.9 for example.
parkern
10-05-2015 12:12 PM
Raffay Khan
Intake and Exhaust
09-14-2015 10:47 PM
