for those of you who have done it.. did you need to move the longblock to get clearance..
as in have to remove motor mounts and raise to get the space..
No, you can remove ecerything from under the car via the rear of the engine. There is a write up or two on the 370z boards that are pretty good. Good luck with the build!
