DIY: How to Install and Hardwire Radar Detector
Old 09-12-2015 | 02:06 PM
  #31
JG_G37's Avatar
JG_G37
Very informative, can't wait to get my radar to hardwire it.
Old 09-21-2015 | 02:09 PM
  #32
bikerjosh's Avatar
bikerjosh
Very cool, thanks. I'd like to get my radar off the custom dash wedge previous owner glued down. Hopefully dash is same color/shade under the mount?
Josh
Old 03-31-2016 | 02:02 PM
  #33
oSnapMillerTime's Avatar
oSnapMillerTime
I decided to run the escort direct wire kit ($15 amazon) to the fuse box with a mini fuse tap. ($7 amazon) I have mine mounted up as high as possible with the factory suction cup mount. The under mirror mount is clean looking but I dont like the radar where people can walk by and see it. Also the instructions state to mount the radar as high as possible. I haven't had any issues with interference from the tint. I can also easily move the radar to rental cars as I can reuse the mount and I still have the cig plug power. I really think this is the best option as opposed to paying for the under mirror mount and mirror tap.
Old 04-08-2016 | 09:05 PM
  #34
TBau651's Avatar
TBau651
I am also not a fan of the RD being super visible from outside the car. Here's another take on a more "stealth" mounting option.. Mirror tapped, mounted with a visor clip and wrapped in a cloth tape that mimics the headliner. You cannot see it whatsoever from outside the car unless you get really low and look for it..
Old 08-12-2016 | 12:17 AM
  #35
SrtUltr's Avatar
SrtUltr
Thanks for the writeup. This just took my 15 mins, I pryed back the white piece to make more room for the leads and it re installed without a problem.
What I bought from amazon. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Old 08-12-2016 | 12:24 AM
  #36
oSnapMillerTime
Originally Posted by SrtUltr
$45
Old 11-29-2016 | 01:29 PM
  #37
zonnie's Avatar
zonnie
anyone know if there is a difference between
https://www.amazon.com/Radar-Mount-M...BP0TFAXZCJ7X80
and
https://store.blendmount.com/mirrort...aps-p3513.aspx
I have a 9500ix
Old 12-05-2016 | 11:05 AM
  #38
oSnapMillerTime
Originally Posted by zonnie
One is fused one is not? Power to the mirror should already be fused so not sure what having another fused line would be good for. At the end of the day you just need power.
Old 02-24-2018 | 06:10 PM
  #39
Pete di Coio's Avatar
Pete di Coio
Just did this in two minutes with the Mirror tap kit. You don't even need to unplug the harness, let alone pull back that white piece. Just use the smallest set of taps and push a bit when inserting.
​​​​​​Pics for reference. I took one and detached the harness to show how easily and secure the smallest taps fit in with a bit of pressure.
Attached Thumbnails How to Install and Hardwire Radar Detector-20180224_162434.jpg   How to Install and Hardwire Radar Detector-20180224_162555.jpg   How to Install and Hardwire Radar Detector-20180224_163021.jpg
Old 03-18-2021 | 05:29 PM
  #40
nicholas1979's Avatar
nicholas1979
Thanks for this. I had got the special cord and mount for my Uniden and installed it today on a 09 g37x sedan using this thread for any help. Install was easy enough and it works great...BUT now when I turn up music because of the subs and amp in my trunk it vibrates the radar detector pretty good and bounces around like crazy if I turn up the sound, mainly because the mount attaches to the mirror mount is my guess. Everything is tightened down the best it will get but will need to figure out what can be done about this issue. Anyone had this problem?
beto4632
10-09-2014 01:38 AM
movinon
10-10-2013 09:02 PM
hobbs
08-04-2011 01:43 AM
Rodzilla
08-18-2009 05:22 PM
kkokko
05-27-2009 07:21 PM
Quick Reply: DIY: How to Install and Hardwire Radar Detector
