New Debadge Method
Old 09-09-2012 | 07:37 PM
Abramite's Avatar
Abramite
New Debadge Method
Hi all,
I decided to Dedadge the G coupe, but I left Mt. Fuji. I found a pretty fast and easy way to Debadge without scuffing and adding scratches to the paint.
After you spray goo gone on the letters, and Use floss to saw them off spray more goo gone and let it soak for a few minutes in the sun. Then instead of rubbing the glue tape with a rag soaked with goo gone ( which is how scratches develop) Use your index finger pad to push on the adhesive and roll it into a ball. You should be able to "smudge" most of the glue/tape off, it rolls up cleanly off the paint. With no damage.
There will be some remnants, so hit the car with some water and a little bit of car wash soap and water mix, then re-soak the area with goo gone for 3-5 minutes ( still in the sun) and repeat the gentle smudging until its spread thin or gone.
Then very gently wipe with a goo gone rag and one more round with the soapy water, then polish and wax, you should end up with no scratches, or at least i didn't.
The key is to start "smudging" when the surface is drying out, if its too wet your finger will slip and slide over the glue.
My car is 3 years old and you can barely see the letters, after a few days in the sun it should be gone completely.
I'm not responsible for damage to your car.
(Made for those who don't have confidence in this process, there is hope)
Enjoy
Old 09-09-2012 | 08:58 PM
Rad_Slinger's Avatar
Rad_Slinger
This isn't really a new technique. People do it different ways. If the finger method worked for you, awesome.
I personally kept heat on the tape soaked in goo gone and worked it off with the dry rag. No scratches.
Thanks for taking the time to write it up though.
Old 09-09-2012 | 10:19 PM
EnviedG35's Avatar
EnviedG35
Yea man..Ive been doing it this way since i started driving....like 15 years ago lol
Old 09-10-2012 | 01:27 AM
Abramite's Avatar
Abramite
Damn, the last few threads I searched everyone talks about how they get tons of scratches and what not. I didn't come across this method before.
I have failed you all ... lol.
Old 09-10-2012 | 01:41 AM
Rad_Slinger
Not at all. Most people dont take the time to write a DIY.
Keep it up. It's people like yourself that keep the board going.
Happy modding!
Old 10-05-2012 | 04:59 PM
Kkitten's Avatar
Kkitten
Out of curiosity, these badges on the car the are not "drilled" in are they? (have not looked yet) also i have always held by lighter fluid as oppose to "goo gone" ... i know 90% of the GOOD bodyshops i have been in will use it, and that way if your fingers are clean it offers a bit of oil as well to help avoid scratching... but again you'll want a clean surface.. so.. if they are not drilled in let me know i may have a new afternoon project... oh and if they are which badges...
Old 10-05-2012 | 05:10 PM
sharkey's Avatar
sharkey
By looking at the pictures, i dont see any holes.
Old 10-05-2012 | 05:45 PM
G37Pillow's Avatar
G37Pillow
They are not drilled on, they are just glued on
Old 10-05-2012 | 05:48 PM
Damn Dirty Ape's Avatar
Damn Dirty Ape
Been doing it this way to remove stuff for a good long while.
Old 10-05-2012 | 06:18 PM
Kkitten's Avatar
Kkitten
well it is a good thing to know, i wasnt aware it had even existed just offering a second method (not trying to step on toes promise)
anyhow thanks guys for the info on this.. may get that done then this afternoon... tyvm!
Old 10-05-2012 | 08:02 PM
Dark Sarcasm's Avatar
Dark Sarcasm
its kinda like rolling up a booger
Old 10-07-2012 | 12:08 AM
HMG37's Avatar
HMG37
Might be trying this out on just the Infiniti lettering. Trunk is too cluttered with badges!
Old 10-07-2012 | 12:09 AM
Drewr4411's Avatar
Drewr4411
this method worked best for me. thanks
Old 10-08-2012 | 10:06 PM
Abramite's Avatar
Abramite
I started with removing the Infiniti, I would have considered leaving the G37, but I have an x so no pretty S to consider leaving so I took it all off
Old 10-08-2012 | 10:29 PM
LexiG37's Avatar
LexiG37
Wow, I was thinking the same thing, then scrooled down and saw your post! Great minds think alike!
Good method OP.
