DIY: Coolant change
Old 06-26-2012 | 01:00 PM
zjoego's Avatar
zjoego
Coolant change
Are there any coolant system vents (other than the radiator cap) to open when draining/refilling the coolant? These vents exist on some vehicles to "burp" the system. Thanks
Old 06-26-2012 | 07:26 PM
vsiev's Avatar
vsiev
I don't think this should be in the DIY thread....but to answer your question....When draining all of engine coolant in the system, open radiator drain plug, remove radiator cap and then open water drain plugs on cylinder block. There should be an air relief plug on the radiator left side and an air relief plug on the heater hose for refilling purposes.
skipmycar (05-26-2024)
Old 07-27-2012 | 05:04 AM
unknowndesi's Avatar
unknowndesi
read page MA 13 on the FSM
fuzzed
08-21-2020 10:35 AM
conkus805
ECU Tuning / Dyno Data
46
11-19-2015 08:49 PM
Rybitron
11-18-2015 04:11 PM
Junchao Sun
25
10-01-2015 01:41 PM
MrRiv
09-29-2015 05:59 PM
