Request for DIY: Seafoam treatment to clean upper part of engine on 2008 G37
Hey folks,
Does anyone have a DIY guide to run seafoam through the vacuum hose / brake booster (?) line on a G37? ...I'm having trouble finding which hose to put the treatment through..
Referred to this article: How to Seafoam your engine the right way. Complete DIY : General Chat
Also, was looking through the FSM without any luck..
Thanks!
Thanks!
Picture(s) with a red circle/arrow would be helpful if you know of any??
Thanks!
I'm at work and can't post a photo. It isn't hard. There's only one easily accessible hose on the brake booster. It's just beside the brake fluid reservoir (to the left side of it when facing the firewall) near the top. Its held on with a compression clamp. It's about 1/2" or so in diameter. That's the one I've used both times I've done it.
Thanks again!
Hey folks,
Thanks!
Thanks!
If you follow that DIY, the last step has a chance to hydrolock your motor.
If you cant even find your brake booster hose, don't even think of doing this.
There are enough detergents in today's fuels, that this is no longer needed.
Im not being rude, Im being factual, and saving your A$$.
""When you get almost halfway through the can, dunk the hose into the can, give it a good "chug" and let it stall the engine (or have your assistant shut off the engine immediately). This will leave a good, wet dose of Seafoam on the cylinder tops
and valves, where it can soak into and dissolve the varnish deposits that hold the carbon together.""
