Anyone have advice on how to hard wire a radar?
I just bought a Passport 9500ix and was wondering if anyone had any advice on how to hard wire the radar detector to the car? I've seen some people selling a radar wire that taps into a fuse, but I'm not even sure where the fuse box on our cars is. If I go that route; what's the easiest place to find a ground wire? I'm planning on getting a rear view mirror mount for the radar as well.
Thanks in advance for any help
Best place is to tap the power from the rear view mirror. there are 3 wires, one is neg the black one, and then one is constant 12v and the other is acc 12v, so itll only turn on with the engine. this is where i have mine hooked up. to tap it i used small gauge single strand wire and put it inside the connector. this is the best way as the wire only has to be like 4 inches
I have a Valentine 1 and the direct wire adapter; is there space up there for the adapter that is 1-3/8" x 3/4 x 3/4.
Also, The direct power adapter has an inline 2a fuse. Would that be removed, or left in. I suspect that circuit is fused, but if it is higher amperage, don't want to fry the V1. What is the color of the switched lead?
Thanks
John
Radar-Mirror
V1 or passport, This is by far the most elegant solution =D
The display is seamlessly integrated into the rear view mirror and you can hide away all the awful clutter and equipment. Not to mention is really cool =D
2 month old g37 coupe owner here. i apologize for the redundancy. i may have made a mistake i wasnt looking to spend too much on a radar detector so i settled for a cobra 9370. it aint a valentine but...Any way i dont have the powered home link mirror and i tried to use the add-a-circuit to try to hardwire into the fuse box. DOESNT WORK. any recommendations??? am i missing a step? thank you
dedmanchan
09-24-2015 11:25 PM
