Toe bolt installation
It's supposed to have a template. Check SPC suspension web site and find the install instructions for your application to print a template. All you need to do is to elongate the eccentric bolt holes about 1/4 of an inch toward the inboard side. The template has you elongate it on both ends which isn't necessary unless you want to run some crazy positive camber.
