Transfer case oil change plus front differential
Old 01-06-2020 | 11:35 AM
  #91
ZzBloopzZ's Avatar
ZzBloopzZ
Nice! I ended up ordering these pumps from Amazon for just $9:
Amazon Amazon
Thanks to RMB5190 for suggesting them!
I personally used Mobile1 75W-90 Synthetic Gear Lube for the differentials. Price was cheap, read great reviews and many people in the trucking forums prefer this to some of the more expensive brand fluids like Redline. The pumps worked PERFECTLY and was a fantastic fit on the Mobile1 containers.
RMB5190 (01-10-2020)
Old 01-06-2020 | 06:49 PM
  #92
Surfnazi's Avatar
Surfnazi
Originally Posted by ZzBloopzZ
Nice! I ended up ordering these pumps from Amazon for just $9: https://www.amazon.com/gp/product/B01LDMXNSO/ Thanks to RMB5190 for suggesting them!
bought same style pump at autozone for 6 bucks
Old 01-06-2020 | 10:53 PM
  #93
ZzBloopzZ's Avatar
ZzBloopzZ
I had originally bought that one from Autozone too, but then realized the Amazon is 2 for $9. I rather use a different pump for the transfer case since it is tough to fully clean out the fluid.
Old 01-18-2020 | 07:57 PM
  #94
VQpoppa's Avatar
VQpoppa
This thread has saved me hundreds by just doing it myself. Thank you too the OP! Front, rear diff and transfer case fluid changed. On a side note, my transfer case fluid looked to have gear oil in it. I've never changed it. I'm hoping it didn't mess anything up too bad. I've changed it over to the correct fluid now so hopefully she's good n happy. 141k miles down still going strong.
Old 02-12-2020 | 01:13 PM
  #95
greggw2gs's Avatar
greggw2gs
Question Awesome DIY!
You think my 2013 G37 Sedan is the same?
Old 02-12-2020 | 01:19 PM
  #96
VQpoppa's Avatar
VQpoppa
i can't say with 100% certainty but i don't think Infiniti changed anything in 3 years. Mines a 2010 sedan.
Old 12-28-2020 | 07:11 PM
  #97
George Alorda's Avatar
George Alorda
Originally Posted by RMB5190
75-90 is fine. That's what I've ran for two changes (60k miles) and the fluid looks great.
Gasket? If you mean plug size, I believe they are they same. Just make sure you have the hex head fully seated in the plug before cranking on it.
hi , but wich year are you been using this gear oil i do have a 2013 g37x and im confused now and i dont have the owner manual . Ahh i do have the x model but weather hot (florida)
Old 12-28-2020 | 09:47 PM
  #98
ZzBloopzZ's Avatar
ZzBloopzZ
I also have a 2013 G37X... this is the fluids you need :
Differentials (3qt Mobil 1 75W-90 Gear)
Transfer Case (2 qt Matic-J)
Make sure it is Matic-J! Sometimes cheaper to get from Amazon.
George Alorda (12-28-2020)
Old 12-28-2020 | 10:44 PM
  #99
George Alorda
thank you sir! .. i heard that the transfer case can use matic-s as the transmission i bought that one since i read that is a substitution for matic j ...what do you think?
Old 12-28-2020 | 10:59 PM
  #100
ZzBloopzZ's Avatar
ZzBloopzZ
From what I researched in this thread, at least for our 2013... Matic-S is NOT a proper substitute for Matic-J. You MUST use Matic-J. I am confident about this as I went through a lot of trouble to find Matic-J when I did this job last year on my car as I personally am all for after market fluids but was told to only use J for transfer case. I ended up getting it from my local Infiniti dealer and I asked if they had discounts since it was $$$ and they took off like 30-40%.
Old 12-29-2020 | 08:42 AM
  #101
RMB5190's Avatar
RMB5190
I used Mobil 1 Full synthetic ATF fluid in the T-case since 30k miles and it was fine until I sold it w/ 100+. Use Nissan fluid for peace of mind if you can but there's alternatives.
George Alorda (12-29-2020)
138
12-23-2022 10:13 AM
buckets
52
07-15-2013 08:38 PM
Ivoidwarranties
07-05-2013 08:36 AM
Modme
131
12-04-2010 10:11 PM
xlack
14
08-30-2010 09:29 AM
Quick Reply: Transfer case oil change plus front differential
