Transfer case oil change plus front differential
#31
Hi guys quick question. I am about to change out all the fluids on my X and I want to verify that for the front diff, rear diff and transfer case we can use Nissan Matic S (J) fluid to replace. I just want to confirm this before I purchase the fluids. So far I know that for 7AT we can use the Nissan Matic S (J) to replace. Thanks in advance.
#33
OK got it. So ill just have to decide which gear oil to use for the front and Rear diffs. Only thing is after i searched I dont think they make Nissan Matic J fluid anymore. So I am assuming the Nissan Matic S fluid is ok for the transfer case? Thanks.
#34
nissan has since replaced all matic j with matic s but other oil manufacturers do still make matic j compatible oils, like royal purple, mobile one, redline, amsoil etc. just be sure to get the right gear oil weight, 75w90.
#35
OK now I see. Final question: So then it is ok to use the RP Max Gear 75w90 for the transfer case, as well as the front and Rear diffs? Thanks.
#36
NO! the differentials and transfer case DO NOT GET THE SAME FLUIDS. please read what i have written in my previous posts. transfer case = automatic transmission fluid ie matic J compatible fluid. Differentials = gear oil, 75w90 variety. I will not be held responsible for your car grenading itself if you put the wrong fluid in the wrong spots.
Edit: sorry if i sounded mad but please reread the entire thread most of your questions can be answered there.
#37
#38
Front differential
Did this, scratch that, TRIED to do this today on my wife's car and I also stripped out the fill hole. As I was *trying* to break the bolt, I managed to smash the oil pressure switch pretty good. Looks like I will have to get to the dealership to get them to drain the front diff (and replace the fill and drain bolts to boot). Great instructions though and I appreciate you putting them up!
#43
I bought a qt of Nissan matic j, but the transfer case requires 1 1/8 qts, the lady at the Nissan parts counter said 1 qt is fine. I went to O'Reillys looking for Castrol import multi vehicle atf which is suppose to be acceptable for the extra 1/8 qt, they don't stock it, but they do have Oreilly Global ATF, which lists Nissan Matic J as an application in the bottle and was $6.19. Any ideas on adding the small amount of O'Reillys atf to the qt of Nissan?
#44
To add to above post;
I bought 2 qts of Redline 75w90 online to change diff fluids(good luck finding a store nearby) and I always change my trans and axles to Redline,works great for smooth operation ,in cold Much.winters! Anyways I thought it would be enough to fill rear and front diff, but I misread the capacities chart in the manual, so I would be 3/8 qt low in the front diff. What if I filled the fear with the required amount of Redline and bought a qt of Mobil 1 75w90 for the front?
#45
