[Pic] Old Air Filters (only used for 1.5 years but it is very dirty already!!)
Old 05-24-2011 | 07:03 PM
04STi208G37's Avatar
04STi208G37
Change when dirty
They are so hard to check for dirt. The hood is so heavy and those little clips are a pain in the neck to get loose. Then you have to wrestle the filter out of place and it never seems to go back in right.
Seriously I check them often and have 4-6 on hand now and change about every 8K when they are dirty. Sometimes I turn them over if they are just starting to show a spot.
Old 09-29-2011 | 04:24 PM
bythabay's Avatar
bythabay
Oiled paper actually filters the most dirt out, that's why they appear to get dirty so quickly. Check out this article off another popular forum where they did an experiment with the most popular air filters on the market - guess which one filtered the best but required frequent replacement?
Air Filtration Test - Bob is the Oil Guy
Old 11-30-2011 | 12:15 PM
370GTSter's Avatar
370GTSter
Originally Posted by norker102
I am so surprised that the filters are SO DIRTY for a 1.5 yrs of usage!
I bought a pair of the new one from Infiniti but they are quite expensive... 55$ Canadian dollars...
if you think those were expensive, trying owning one in Australia $45 AUD each = $90 per swap, and that if the dealer knows you know what you want, otherwise $120 each. Since out G37 (370GT) are all imports, they tend to really screw you!
Old 11-30-2011 | 02:44 PM
bythabay's Avatar
bythabay
I can get the NPN filters for about $5 each.. They look almost identical
Old 11-30-2011 | 03:41 PM
tejasg37x's Avatar
tejasg37x
I hope your were not serious about this...where do you think the dirt will go if you turn them over?
Old 11-30-2011 | 03:43 PM
bythabay's Avatar
bythabay
I think he's talking about rotating them, not flipping them over It's physically impossible to install them the wrong way since the seals won't line up properly.
Old 11-30-2011 | 10:36 PM
04STi208G37
yes, i rotate them. I was kidding about the difficulty but not about this. I do change them oftern and I think 8k is plenty off mileage for these and I do NOT buy them from the Stealership so I don't think they are expensive either. Clean filters do save a little gasoline, too.
Old 12-01-2011 | 12:23 AM
tejasg37x's Avatar
tejasg37x
The flipping them over part was misleading...now I understand what you are saying.
superjoey
31
03-23-2023 12:56 AM
Thedbarz
33
02-09-2016 01:05 AM
BANNISTER
12-10-2015 05:14 PM
xpcgamer
Intake and Exhaust
08-04-2015 03:18 PM
Quick Reply: [Pic] Old Air Filters (only used for 1.5 years but it is very dirty already!!)
