DIY: Grounding kits made simple, step by step guide to making your own!
Old 01-01-2014 | 11:51 PM
  #91
GoFightNguyen's Avatar
GoFightNguyen
Because Racecar
Originally Posted by warped ideas
Sheathing around what?
Your wire will be insulated to protect the copper, but there is a PVC woven sheath you can put around the insulation to guard against rubbing and abrasion. There's also heat insulation available if you want, I didn't get it.
Old 01-01-2014 | 11:52 PM
  #92
warped ideas's Avatar
warped ideas
A quarter past stripped
Oh okay. Good tip. Thanks
Old 01-02-2014 | 09:21 PM
  #93
warped ideas
Okay... Installed "grounding kit". The verdict is still out......
Old 01-02-2014 | 10:16 PM
  #94
Darth Kinetic's Avatar
Darth Kinetic
No. This thread really HAS come to a verdict.
Old 01-02-2014 | 10:26 PM
  #95
warped ideas
Audio may be a little louder, but I haven't felt a difference in DS mode shifting or throttle response. I bet the Uprev tune will cure all THOSE ailments though.
Old 01-02-2014 | 10:38 PM
  #96
Darth Kinetic
Can I get that with two spoons of sugar
Old 01-02-2014 | 10:44 PM
  #97
warped ideas
And a WHOLE LOT MORE! Uprev T-minus 3 weeks and counting!
Old 03-06-2014 | 09:02 PM
  #98
kmchenry's Avatar
kmchenry
[QUOTE=AZg37;3116373]
What size eyelits do i need?
Old 03-06-2014 | 09:04 PM
  #99
GoFightNguyen
Because Racecar
Holy ****. Quoted the entire post and apparently didn't read ****, because it says so right on the first few pics. 8 gauge and 4 gauge.
Old 03-06-2014 | 09:45 PM
  #100
kmchenry's Avatar
kmchenry
Ordering 4 and 2 g copper post, the vendor wants to know what size ring / eyelet for when you ground it.
Old 03-16-2014 | 06:39 PM
  #101
FRChilln's Avatar
FRChilln
Was skeptical myself but shifts were drastically improved in Sport paddle mode. Thanks for the DIY
Old 03-18-2014 | 01:34 AM
  #102
Domate's Avatar
Domate
AZg37,
Kudos my man, this DIY is up there with the best on this site! Shifting is spot on now in DS mode and audio is noticeably improved!!
Thanks mate!
doug
Old 03-23-2014 | 05:45 AM
  #103
HoldmyMouse's Avatar
HoldmyMouse
Do you guys get stranded or solid?
Old 03-23-2014 | 06:00 AM
  #104
Gwhizz's Avatar
Gwhizz
Stranded
Old 03-23-2014 | 06:05 AM
  #105
dgey1's Avatar
dgey1
I made my kit with stranded cable, better conductivity, more pliable and stronger to boot. used the recommended cable size, 8 and 4 gauge also. I didn't go crazy with the quality cable and bought my stuff from home depot, and eyelets from a car audio store. I used shrink tubing to cover any bare cable to connector.
Audio in my car is better. Tranny shifting is better up and down. It is noticeable... Also don't wait for the factory recommended 105,000 miles to change your plugs. Incredible difference when all is said and done.
Doug
