Help!
Help!
HELP! Not sure if I posted in the right place. My 08g37 has the drivers side key delete installed. my battery died and i cannot get into my car to pop the hood to jumpstart the battery, what can i do?
please Help me!
please Help me!
Mr. Drop it like it's hot
http://en.wikipedia.org/wiki/Slim_Jim_(lock_pick)
I would leave that to a professional though.
But can you remove the keyhole cover with something.
why dont you just remove the keyhole delete the same way you removed the original one?
Then you can you use your key to unlock. OR
if you have some fairly strong wire, bend it into a hook and look through the grill, there will be a black wire going across up near the radiator shroud, hook the wire hook onto it and pull, this will pop the latch. I did this when i incorrectly reinstalled the shroud a while ago.
You had time to start this thread an access to a computer, but you didn't bother to search how to remove the key delete...wtf
https://www.myg37.com/forums/g37-cou...-pictures.html
