Request:Need help installing white leds for rear license plates lights
Old 10-31-2010, 12:01 AM
carfan23
carfan23's Avatar
If anyone can point me in the right direction on how to do the install and wat bulbs to use. I searched around the forums but all i find was an install for some really bright LEDs that turn on wen the car is in reverse. I'm looking for regular plate lights just whiter than factory. Thanks in advance fellas.
Old 10-31-2010, 12:36 AM
CDONNS
CDONNS's Avatar
This thread is great for all of your lighting needs....https://www.myg37.com/forums/body-in...-used-fyi.html
As for the install, it's really simple. Just get down there and look at them, should be easy to figure out how to remove (simple unclip). If you still can't figure it out, i'll do a quick DIY.
Old 10-31-2010, 12:39 AM
cvipgo
cvipgo's Avatar
Following are links to best LEDs & more you can buy for your Infiniti G37:
Front/Rear Turn Signal - Super Bright LED Car Lights, Automotive LED Bulbs, LED Strip Lights, HID Light Bulbs, HID Conversion Kits and more
Fog - H1 LED Bulbs Infiniti G37 Fog Lights Honda S2000 DRL Daytime Lights
Side marker/License Plate/Trunk - Super Bright LED Car Lights, Automotive LED Bulbs, LED Strip Lights, HID Light Bulbs, HID Conversion Kits and more
Map - 6-SMD 31mm 1.25" DE3175 DE3022 Interior Map Dome LED Light Bulbs
Reverse - 360¡ã 68 SMD T10 168 921 912 Bulbs for Parking, Back up Reverse Lights
Old 10-31-2010, 01:55 AM
CDONNS
CDONNS's Avatar
Alright, here you go. Embarrassingly easy, but totally understand. BTW, I got the ones from the thread I posted before. Highly recommend them for 9 bucks, I would recommend doing the dome lights and door lights too. Much better with the clean white look, easy mod for only 30 bucks.
Push this clip in, and the light will pop out (there are two seperate lights)
<a href="http://picasaweb.google.com/lh/photo/0hsIelG0LyzZ9lNfQtGzlT-i8iGV_Baxfy489B4A0wE?feat=embedwebsite"><img src="http://lh5.ggpht.com/_35mFCvMJ5Js/TM0DXs0tPwI/AAAAAAAABFI/1yiDvRHTFd4/s400/photo%201-5.JPG" height="400" width="298" /></a>
Twist the housing CCW to unseal it, then remove old bulb and put in the new one. Dont put it all back together until you test them, if they turn on you're good to go, if not then take them out and flip them around. Put back together and enjoy.
<a href="http://picasaweb.google.com/lh/photo/I3UO43RxeSEjcAgXzpqI8j-i8iGV_Baxfy489B4A0wE?feat=embedwebsite"><img src="http://lh4.ggpht.com/_35mFCvMJ5Js/TM0DYKtO2wI/AAAAAAAABFQ/WYAXIucEWek/s400/photo%203-4.JPG" height="400" width="298" /></a>
<a href="http://picasaweb.google.com/lh/photo/RyIDZ1uMTybj1T6I34VSaT-i8iGV_Baxfy489B4A0wE?feat=embedwebsite"><img src="http://lh5.ggpht.com/_35mFCvMJ5Js/TM0DYXPWWeI/AAAAAAAABFU/Mh767WBnRKw/s400/photo%204-3.JPG" height="400" width="298" /></a>
Old 11-01-2010, 07:31 PM
CDONNS
CDONNS's Avatar
Per your request, here's the dome and door light install. Just need a flat head screwdriver with some tape on the tip so that you don't scratch anything.
The dome light is a simple pop out, don't worry you won't break anything. It has four clips, two on each side....
<a href="http://picasaweb.google.com/lh/photo/5dntYA_F1zKbPmidIAKiPj-i8iGV_Baxfy489B4A0wE?feat=embedwebsite"><img src="http://lh6.ggpht.com/_35mFCvMJ5Js/TM9KxGIWXII/AAAAAAAABFw/_0rW6nklI-4/s400/photo%201-1.JPG" height="400" width="298" /></a>
<a href="http://picasaweb.google.com/lh/photo/ZWaVm8cRhAvuCDSngvBURz-i8iGV_Baxfy489B4A0wE?feat=embedwebsite"><img src="http://lh6.ggpht.com/_35mFCvMJ5Js/TM9KxVppjmI/AAAAAAAABF0/v4GfM8k_Z0c/s400/photo%202-1.JPG" height="400" width="298" /></a>
The door lights are the same, pry it out. Then I would recommend disconnecting the wire harness, just push down the little clip and it'll come right off. Then, you'll want to pry off the clear plastic piece. Just pop one side off and you should be good to go. Once again, don't close everything up and put it back together until you verify you have them in correctly...
<a href="http://picasaweb.google.com/lh/photo/vM1prIVaqPCl_8WHEgB_iT-i8iGV_Baxfy489B4A0wE?feat=embedwebsite"><img src="http://lh5.ggpht.com/_35mFCvMJ5Js/TM9KxvaDSgI/AAAAAAAABF4/1buy0L9tppE/s400/photo%203-1.JPG" height="400" width="298" /></a>
<a href="http://picasaweb.google.com/lh/photo/Ot9UwoAhcWtR4KYSjzDoQT-i8iGV_Baxfy489B4A0wE?feat=embedwebsite"><img src="http://lh6.ggpht.com/_35mFCvMJ5Js/TM9Kx4k7CFI/AAAAAAAABF8/TX-xPio_69g/s400/photo%204-1.JPG" height="400" width="298" /></a>
<a href="http://picasaweb.google.com/lh/photo/ltcVgrjVopAs5ziYChLvDj-i8iGV_Baxfy489B4A0wE?feat=embedwebsite"><img src="http://lh3.ggpht.com/_35mFCvMJ5Js/TM9KyRri4PI/AAAAAAAABGA/IqjFHu-FBZQ/s400/photo%205-1.JPG" height="400" width="298" /></a>
Old 11-05-2010, 08:35 PM
carfan23
carfan23's Avatar
Just finished!
I got the bulbs in today and I was done in like 15 minutes with the help of this thread. Lovin it and would recommend to anyone who wants that crisp clean look.
Old 11-06-2010, 01:17 AM
CDONNS
CDONNS's Avatar
Good to hear man, I think it is one of the most noticeably effective mods you can do for the price.
Old 11-08-2010, 08:43 PM
tWistedMissiOn
tWistedMissiOn's Avatar
Anyone know whether the side turn signal cover can be open? Any DIY on that?
Old 11-09-2010, 08:33 AM
CDONNS
CDONNS's Avatar
I'm not 100% sure what you're referring to, do you mean within the headlight housing? Or, do you have one on the side of your car since you're from a different country?
Old 11-09-2010, 10:36 AM
marcelo19lp
marcelo19lp's Avatar
Nice picture write up with descriptions, how do you install the Reverse light back up?
Old 11-10-2010, 10:39 AM
mystakin
mystakin's Avatar
CDONNS, you got any pics of them lighted up at night? i got cheap single led bulbs from local auto shop and they dont output enough light imo. just wondering how yours with the multi led setup on each bulb looks
Old 11-10-2010, 02:23 PM
Mid-Life Crisis
Mid-Life Crisis's Avatar
See this DIY:
https://www.myg37.com/forums/d-i-y-i...-1-of-2-a.html
Old 11-10-2010, 11:41 PM
tWistedMissiOn
Hey man, thanks for replyin, i meant the side, below the mirror on the side fender. Sorry if i got the wrong term for it.
Old 11-11-2010, 10:21 AM
CDONNS
CDONNS's Avatar
I don't have any but I used these lights in this thread, they look amazing. Pics don't really do them justice but there is no yellow tint whatsoever in the actual lights. For $9 a pair, I'd go with it
https://www.myg37.com/forums/body-interio...-used-fyi.html
Old 11-11-2010, 10:24 AM
CDONNS
CDONNS's Avatar
Hmmm, I'm not sure how to get to it. My car, along with all US spec'd ones (I assume), don't have that light.
Quick Reply: Request:Need help installing white leds for rear license plates lights
